Alternator problems
Old May 19, 2004 | 08:01 PM
DC4noMore's Avatar
Default Alternator problems
A roommate of mine has a '90 crx si and his alternator is bad. So today we went to replace it but we couldn't get it out. It is completely unbolted but there isnt enough clearance anywhere to pull it out. I used to have an '89 dx and I swapped the alternator on that and we had to jimmy it under the IM and pull it out by the intake. I've heard the si's are slightly different and you have to drop the axle to take it out. Is this true?, or can we take it out by going under the IM? If we have to drop the axle, what size socket is it and any pointers on how to do it. I've never removed one before. Thanks.
Old May 19, 2004 | 08:17 PM
Redline130's Avatar
Default Re: Alternator problems (DC4noMore)
I think you may have to remove the axle to get the alternator out. However, I've been able to pull the alternator out of my CRX with a B16 out from the top. Just had to remove the fuel pressure regulator, couple of hoses, clutch cable, and do some twisting and contorting. Much better than pulling an axle IMO. Might be worth a shot. The axle nut is a 32mm. If you have an impact gun, it would make it an easier job.
Old May 19, 2004 | 09:01 PM
civickiller's Avatar
Default Re: Alternator problems (Redline130)
the way i got my mine in was through the crank pulley area, i had to take out the crank pulley and the pivot point mount for the alt and some wiggling in and i got it there. but this was for my ls with place racing mounts
Old May 20, 2004 | 01:45 PM
DC4noMore's Avatar
Default Re: Alternator problems (civickiller)
Thanks guys but bump for some more info...anyone actually done this on a crx si?
Old May 20, 2004 | 01:56 PM
kylefakesi-r's Avatar
pull the axle out and let it hang with teh inner joint wedged in the fork so it won't fall out and get messed up. remove the oil filter and just slide it down. lots of room if you do it this way. really easy if you ahve a hoist at your disposal.
Old May 20, 2004 | 02:20 PM
7PSI CRX's Avatar
Get the car up on jackstands.
Remove the Drivers' side wheel.
Remove the alternator "Bracket" on the back of the block.
Unlock the steering.
Using a combination of flips, spins, and steering movements, it'll come out the wheelwell.
Old May 20, 2004 | 03:37 PM
137's Avatar
137
Default Re: Alternator problems (7PSI CRX)
lol I can unbolt my alternator while the car is seated, and pull it out from the top.
Old May 20, 2004 | 05:23 PM
90LSpimpin's Avatar
Default Re: Alternator problems (137)
I just did this like a week ago. My lower bracket wouldnt come off cus one of the bolts was rusted and stripped, so i didnt have clearance from under the car. Unbolt the brake master cylinder, move it over behind the intake manifold, if you be easy with it the lines shouldnt break. From hear you should have a good amount of space to pull it out. Took me 5 mins to get it back in. Good Luck
Old May 20, 2004 | 08:47 PM
DC4noMore's Avatar
Default Re: Alternator problems (WeaponRex86)
My roomie tryed to take off the bracket but he said it was rusted tight. I'll try to give it a shot tomorrow but in case that doesn't work, won't brake fluid leak out everywhere if I unbolt the master cylinder?
Old May 20, 2004 | 09:26 PM
CRXDrew's Avatar
Yea, screw taking the axel off. I guess you gotta listen to weapon on this one.
By the way Brandon... u might aswell change ur name... u only have 11 posts and the rex has been long dead.
Old May 22, 2004 | 02:19 PM
DC4noMore's Avatar
Default Re: (CRXDrew)
Ok guys we got it. We just used a syringe to get as much brake fluid out of the master cylinder as we could, then we unbolted it and the alternator came right out. Thanks alot guys.
Old May 22, 2004 | 02:38 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">Get the car up on jackstands.
Using a combination of flips, spins, and steering movements, it'll come out the wheelwell. </TD></TR></TABLE>
Yep, but if you have a different engine in your car like a b16 it won't come out like that , when you unbolt the master cylinder no fluid will come out.
Old May 22, 2004 | 02:39 PM
B2FiNiTY's Avatar
Default Re: Alternator problems (90blackcrx)
I pull it out from the top, lots of wiggling and moving of wires out of the way.
Old May 22, 2004 | 03:32 PM
7808's Avatar
Default Re: Alternator problems (B2FiNiTY)
i just did this on a 90 hatch,
just slide it across the firewall to the passenger side, then disconnect a few coolent hoses and intake tube, then pull it up through there.
Old May 22, 2004 | 08:16 PM
honcrx91si's Avatar
Default Re: Alternator problems (fuctup)
I just did this last week to my 91 crx si and that is exactly what u have to do... it comes out you just gotta work it till it does.. i know it is a bitch we had to do it my a school parking lot... and take some of the the plastic stuff around the axel off too that helped me.
Old May 22, 2004 | 10:35 PM
CyniKal.Mindset's Avatar
Default Re: Alternator problems (honcrx91si)
all u have to do is unbolt the master cylinder from the booster...move it out of the way and pull it up through there...no messing with brake fluid or nuthin!
I changed mine on the side of the highway like that. put in the new alternator and belt, bolted back the master cylinder onto the brake booster, started the car and I was on my way...you guys like doin things the hard way!
Weapon knows where its at!
.kory
Sep 11, 2009 01:28 PM
addiction2bass
36
Feb 18, 2009 05:30 AM
97VtecIN
Nov 7, 2004 08:52 AM
djay86
Oct 2, 2002 04:23 PM
unKnown
Oct 12, 2001 09:15 AM
