P72 ECU good for LSVTEC setup?
Old May 19, 2004 | 06:48 PM
I3ackfire's Avatar
Default P72 ECU good for LSVTEC setup?
With a B18A bottom end, and a 95 GSR Head, and Intake manifold, can I use a 972 gsr JDM ecu?
All search's that I do people say chipped p28, why?
Old May 19, 2004 | 09:19 PM
m00tjam's Avatar
Default Re: P72 ECU good for LSVTEC setup? (I3ackfire)
its cheaper?
just stick with the p72
Old May 23, 2004 | 05:43 PM
99lsvtecauto's Avatar
Default Re: P72 ECU good for LSVTEC setup? (m00tjam)
dont forget 2 run k/s or u will throw codes
Old May 25, 2004 | 10:39 PM
I3ackfire's Avatar
Default Re: P72 ECU good for LSVTEC setup? (99lsvtecauto)
k/s?
Old May 26, 2004 | 12:18 AM
maxxborist's Avatar
knock sensor
Old Jul 17, 2004 | 12:45 PM
.Eddie's Avatar
Default Re: P72 ECU good for LSVTEC setup? (maxxborist)
Don't rev to high and keep it at around 6500 to be safe.
Old Jul 17, 2004 | 09:42 PM
A1's Avatar
A1
Default Re: P72 ECU good for LSVTEC setup? (killerb20zallmotor)
chipped p72
honda connection
5511 mision st. sf/ca
4155871079
Old Jul 21, 2004 | 10:10 AM
Circuit Star-29's Avatar
Default Re: P72 ECU good for LSVTEC setup? (d16why8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerb20zallmotor &raquo;</TD></TR><TR><TD CLASS="quote">Don't rev to high and keep it at around 6500 to be safe.</TD></TR></TABLE>
Ok, shift before the engine makes peak power right?
Old Jul 21, 2004 | 10:38 AM
Phatch99's Avatar
don't mean to jack your thread but can you just tap into the knock sensor wire from the engine harness and ground that to the battery?
mesonerz
Oct 1, 2007 08:23 PM
tmk819
Dec 11, 2006 07:35 AM
poweredbysol
Feb 28, 2006 11:19 AM
H22SRV
Feb 2, 2005 11:21 AM
TABIAS
Jul 14, 2004 10:37 PM
