I mis-shifted.....
Ok, I was racing a Lexus on the way home (yes, i know, street racing is bad....) And the 1st time was great, I got him by a couple of car lengths. But the second time is a different story. I was pulling on him at 3rd and realized it was time to shift, so I attempt to shift to 4th, and 2nd decided it was going in instead of 4th. So i hear my car scream like a bat out of hell, and quickly push in the clutch. i see my tach go wayyyyyy passed what it even registers. But this was for a split second. Do you think i might have floated my valves? Is there anyway to tell what rpm i went to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">Does the car drive/sound any different right now??</TD></TR></TABLE>
um...not really for sure yet, if i had to say anything its more hesitate now...
the same thing happend to me at the track. i was going in 3rd and i guess 2nd gear decided to go in. 1st of all does your car start funny and turns off, if it does you may have bent valves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94extrix »</TD></TR><TR><TD CLASS="quote">you should do a compresion test.
- i agree, just to be on the safe side...just run a few tests to see how its running on the inside
but i think you should be fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94extrix »</TD></TR><TR><TD CLASS="quote">the same thing happend to me at the track. i was going in 3rd and i guess 2nd gear decided to go in. 1st of all does your car start funny and turns off, if it does you may have bent valves.</TD></TR></TABLE>
Actually when its cold it has a hard time running, rpm's want to fall until it dies....
bent valves.. happens all too often,
a compresion test /leak down test prefrebly will tell
a friend with a gsr did this, when you pull the head, you can see which valves arn't seating correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">bent valves.. happens all too often,
a friend with a gsr did this, when you pull the head, you can see which valves arn't seating correctly.</TD></TR></TABLE>
Thats great, my friend had bent exhuast valves and he shot flames....should i expect the same?
You'll know when you bend your valves from a mis-shift, most of the time the motor will not idle properly and it tends to hesitate and sputter throughout the RPMs. But like everyone else stated above, your best bet is to do a compression test or a leak down test, that should tell you if your valves are bent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caLiH22A »</TD></TR><TR><TD CLASS="quote">You'll know when you bend your valves from a mis-shift, most of the time the motor will not idle properly and it tends to hesitate and sputter throughout the RPMs. But like everyone else stated above, your best bet is to do a compression test or a leak down test, that should tell you if your valves are bent.</TD></TR></TABLE>
Ya, my valves are bent, it does all that. Sputters, spits, idles wierd. Oh yeah, did i mention it DOES shoot flames out the back....Thats great
mrmonk
Dec 29, 2003 10:13 AM
