::rounded off upper strut bolts!!??::
Old May 19, 2004 | 04:38 PM
spock_rocker's Avatar
memoryFAB.com representative
Default ::rounded off upper strut bolts!!??::
yes i did a search but that didn't help much. what should i do to get this **** taken care of?? damned breaker bar... i couldn't get those bolts loose for the life of me and thats what happened... any help would be appreciated
Old May 19, 2004 | 04:44 PM
I'll cut ya!'s Avatar
Default Re: ::rounded off upper strut bolts!!??:: (spock_rocker)
lefty loosey righty tighty....
Old May 19, 2004 | 04:56 PM
pdiggitydogg's Avatar
Old May 19, 2004 | 04:59 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (pdiggitydogg)
yeh it works great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
what I usually do when I don;t have that tool anywhere near me, I just turn the nut clockwise (tighty) and then loosen it again to get rid of the dust that is possibly holding the virgin nut in place
Old May 19, 2004 | 05:27 PM
jeffk182's Avatar
Haha when I was putting in my tokico's, my friend stripped one of the nuts. So we got a chisel and broke that damn nut and went to a car shop, dug through a big bucket of bolts and nuts and replaced =D The chiseling took 2 hours...try using the tool they showed you to save time.
Old May 19, 2004 | 05:38 PM
esoterEK..'s Avatar
dont work for my mount bolt..doesnt fit that well in place to even loosen it a bit..
Old May 19, 2004 | 05:40 PM
Archidictus's Avatar
Unceasing Measure
You need to hammer it on then. Jesus Christ: use some vice grips or something .
Old May 19, 2004 | 05:43 PM
theyre designed to be hammered/tapped on...
Old May 19, 2004 | 05:46 PM
TurboBumblBee's Avatar
that craftsman kit is AWESOME!! it has saved me as well as couple friends a couple of times... they make one that has more bits in it also line 14 bits you should be able to get anything off w/ that
Old May 19, 2004 | 08:13 PM
Default Re: (Boostfedb18c1)
well i couldn't use the craftsman set, i need an extended socket. the strut bolts are to long. its the nut that i rounded off
Old May 19, 2004 | 08:25 PM
FrostySol's Avatar
Default Re: (spock_rocker)
un-round 'em ... other than that not too sure what to say...
Old May 19, 2004 | 08:27 PM
Ryan C's Avatar
Default Re: (FrostySol)
vise grips, good ones
Old May 19, 2004 | 08:32 PM
FrostySol's Avatar
Default Re: (Ryan C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">vise grips, good ones</TD></TR></TABLE>
yeah that's prolly a more practical solution than the one I posted... try the grips first before the dremel. Good luck getting em off... I hate rounded, siezed, and otherwise troublesome nuts and bolts
Old May 19, 2004 | 08:44 PM
worse comes to worse i'll have to pay a shop!! eg
Old May 19, 2004 | 09:07 PM
743power's Avatar
First off, if you're talking about the suspension on an eg or ek, you are talking about a shock absorber, not a strut.
My friend was doing suspension on his AE86. The nut was jammed, and ended up rounding off. It was 12mm originally, so my friend hammered an 11mm 12pt on, and it turned right off.
Old May 19, 2004 | 09:11 PM
Default Re: (x743x)
im talking about the nut at the top...thats actually on the inside of the car..
Old May 19, 2004 | 09:24 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">im talking about the nut at the top...thats actually on the inside of the car.. </TD></TR></TABLE>
i dont understand? can you post a picture or something? Inside of car?
Old May 19, 2004 | 09:41 PM
jeffk182's Avatar
It holds the strut upper pillow mount in place. 93-00 have 2 bolts that hold them
Old May 19, 2004 | 09:46 PM
743power's Avatar
Default Re: (jeffk182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffk182 &raquo;</TD></TR><TR><TD CLASS="quote">It holds the strut upper pillow mount in place. 93-00 have 2 bolts that hold them</TD></TR></TABLE>
yea, but thats not inside the car. That nut can easily be removed with a smaller sized socket, or with nut extractors or vise grips.
Old May 19, 2004 | 10:00 PM
JforJonathan's Avatar
Default Re: (x743x)
damn i did this to mine too....vise grips did nothing. so i just left it on there. i had to just take it apart by the actual strut nut. so i guess i cant get an upper strut bar for my rear
Old May 19, 2004 | 11:26 PM
MPower332TI's Avatar
Default Re: (JforJonathan)
Those nuts are 14mm's. So get ethier a 13mm or a 1/2inch socket and hammer that **** on the nut. Hammer it till it sits flush, then throw your ratchet on it and take that **** off.
Old May 20, 2004 | 04:56 PM
Default Re: (jDmDxTuRd)
something ill have to try... i miss you shawn!
mhng
Jun 3, 2005 04:20 AM
efhatchster
Feb 6, 2005 09:27 AM
Sethypoo
17
Jun 29, 2004 02:38 PM
FitCRX
Mar 1, 2003 03:57 PM
J28S
Mar 10, 2002 07:33 PM
