Good How-To for installing a Strut bar?
Old 06-27-2004, 12:51 PM
Sethypoo's Avatar
Default Good How-To for installing a Strut bar?
I'm having a hard time finding a good how-to for installing a strut bar. Suggesstions?
Old 06-27-2004, 12:52 PM
memoryFAB.com representative
spock_rocker's Avatar
Default Re: Good How-To for installing a Strut bar? (Sethypoo)
unbolt the nuts from the struts and install... reverse the process.. should take about 5 minutes. unless you strip the nuts like i did.
Ricey McRicerton's Avatar
Are you talking about a strut tower bar for the front? It should be 2 bolts. Pretty self explanitory IMHO.
Old 06-27-2004, 12:53 PM
92b16vx's Avatar
Front or rear? Either way, just unscrew the two bolts holding the shock on from inside the engine bay (or trunk), and put it on, and tighten the bolts back.
Old 06-27-2004, 12:55 PM
pdiggitydogg's Avatar
unless its one where you need to drill new holes...then you add a step
Old 06-27-2004, 01:21 PM
Electrician
Deemeetree's Avatar
Unbolt.
Install.
Bolt.
If you can't do it or if you have problems like that other d00d installing a tach, sell your car and take public transportation.
Old 06-27-2004, 01:55 PM
EvilPinkEye's Avatar
Default Re: (Dimi)
ouch
Old 06-27-2004, 02:10 PM
Louie_EM1
Guest
Posts: n/a
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">
If you can't do it or if you have problems like that other d00d installing a tach, sell your car and take public transportation. </TD></TR></TABLE>
Omg, just shut the **** up. People like you are demeaning to the highest caliber.
Old 06-27-2004, 02:11 PM
Honda.F1's Avatar
Default Re: Good How-To for installing a Strut bar.
http://www.geocities.com/Motor....html
geocities.com/MotorCity/Flats/3877/Rear_Strut_Bar.html
http://hazone.com/hstrutbar.htm Front bar
Modified by Honda.F1 at 4:40 AM 6/28/2004
Old 06-27-2004, 02:13 PM
JDMflavor_EJ's Avatar
Default Re: (Louie_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
Omg, just shut the **** up. People like you are demeaning to the highest caliber.</TD></TR></TABLE>
Tell me about it...
Just answer the question, for God's sake.
I bet he almost felt obligated to make a smart *** remark.
He even 'explained' in his sig he accutally isn't a trial member, and how many posts he had before; like people give a ****.
Pathetic...
Old 06-27-2004, 02:21 PM
da935oul's Avatar
darn TAXANs yeeeHAAAAAAAA. jk, but dont be a smart ***, there are always newbies who need help, and this is what we are here for.
Old 06-27-2004, 02:30 PM
Electrician
Deemeetree's Avatar
God damn, it's called sarcasm. Everyone get the banana out of your *** and RELAX! It's a damn joke.
To the original poster, it isn't hard at all. There is no need for fabrication (unless you need to drill, if you need to...mark your holes and drill), there is no tech involved really. Remove the strut tower bolts, adjust the strut bar (if applicable) and bolt down.
Best way to do it, jack the entire front end up, THEN install it and make sure it's tight, then drop down so all the flex will be less.
Happy?
Old 06-27-2004, 02:32 PM
Electrician
Deemeetree's Avatar
Default Re: Good How-To for installing a Strut bar. (Honda.F1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda.F1 &raquo;</TD></TR><TR><TD CLASS="quote">"He even 'explained' in his sig he accutally isn't a trial member, and how many posts he had before; like people give a ****.
To you, oh dumb one, when I had 2 posts everyone was calling me a n00b and people were surprised how much information I had for being a n00b. Had to clarify. If you don't give a ****, good for you, you can go back to the rock your crawled from. I didn't place it there so people can care, just for clarification.
Old 06-28-2004, 03:48 PM
Sethypoo's Avatar
Default Re: Good How-To for installing a Strut bar. (Dimi)
If I loosen the bolts, will the pressure from the shocks/springs be dangerous? Should I have my car up in the air, like on a lift type of thing they have in auto shops? Sorry, my n00b-ness is tough.....
Old 06-28-2004, 03:50 PM
Default Re: Good How-To for installing a Strut bar. (Sethypoo)
Just leave the car sitting on the ground. The shocks will be held down by the weight of the car and you'll be fine. No problems unless you don't bolt the shocks back up and decide to go jump the car . If you have any specific problems feel free to PM me.
Old 06-29-2004, 02:11 PM
Sethypoo's Avatar
Default Re: Good How-To for installing a Strut bar. (Ricey McRicerton)
Is there a special amount or torque I need to apply to the bolts for the installation of a front strut bar?
Old 06-29-2004, 02:15 PM
DC24jooo's Avatar
Just make it tight so your cars vibration willn't make it come lose
Old 06-29-2004, 02:38 PM
asmallsol's Avatar
just make sure you line the strut car up and see what bolts that you have to undo. Its really problly the eaiest "mod" you can do
Don't loosen the nut that is threaded on the shock rod, undo the 2 beside it (if you have that style).
Bad_dude
03-09-2012 04:07 AM
apalmucci
22
03-23-2011 01:36 AM
chahsiubow
09-05-2005 12:33 AM
vaajboy
09-08-2004 06:58 AM
neo1z
01-10-2002 10:03 PM
Quick Reply: Good How-To for installing a Strut bar?
