Resurface Flywheel?
Old May 19, 2004 | 03:55 PM
vtecb20coupe's Avatar
B A N N E D
Default Resurface Flywheel?
just wondering if i should resurface the flywheel if i'll be using my old clutch when i drop my motor back in my car? it's got about 6 months left on it and i just wanted to use the same clutch/flywheel for the initial motor break-in. once the motor is fully broken in, i'll be replacing the cams, clutch, and flywheel. besides, i didn't want to spend $40 on the resurface this time and another $40 again when i install the new clutch.
i know most of you would say wait until you have everything, and save myself time and money but that's not really the issue right now. while the motor is out, i'm having the engine bay painted so i don't have all the time in the world.
thanks for the help.
Old May 19, 2004 | 04:13 PM
EL Vap133's Avatar
Default Re: Resurface Flywheel? (vtecb20coupe)
I would do it if I installed a new clutch.
Old May 19, 2004 | 04:42 PM
HATCHingMN's Avatar
resurface only when install a new clutch!!
Old May 19, 2004 | 06:18 PM
B A N N E D
Default Re: Resurface Flywheel? (HATCHingMN)
ok, sounds good to me. i'll just get it resurfaced when i get the new clutch installed later.
Old May 20, 2004 | 01:37 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
alot of places resurface for 20.. 25 max... its worth it to me..
Old May 20, 2004 | 03:19 AM
B A N N E D
Default Re: Resurface Flywheel? (Built B16A)
not around here they don't.
Old May 20, 2004 | 10:29 AM
Built B16A's Avatar
ide offer to have it done for 20 bucks for you, but youde loose the cost in shipping. i have mine all doen at clutchmasters.. yes, im near by, and they're in Rialto... 20 bucks.. walk in special.
Old May 21, 2004 | 03:39 AM
B A N N E D
that's cool. i appreciate the offer though. oh well, just as long as the old clutch holds up throughout the initial break-in, i'll be happy.
B_Swapped93
Apr 4, 2013 06:30 PM
SingledOut
Transmission & Drivetrain
Aug 26, 2010 04:36 PM
Ralleh
Honda S2000
11
Oct 13, 2009 05:40 AM
EF_LSVtec
Jul 11, 2002 08:53 AM
