building an engine
Old May 19, 2004 | 03:17 PM
goodOLdayz's Avatar
Default building an engine
ok lets say i get the helms manual and put together a whole engine. and it was put together the right way. what troubles would i come across down the road ?
how would i register it? would it be cheaper than buying a whole swap ? how hard would it be for someone who knows the basics, and follows ood instructions?
im asking this cuz , duh, the idea has been running through my head. but i dont have the dough to pay for the whole thing now, so i was maybe hoping on slowly building one myself. what do you guys think?
Old May 20, 2004 | 08:28 AM
goodOLdayz's Avatar
bump cuz i know its a bit noobish but id still like an answer
Old May 20, 2004 | 09:05 AM
JDMotive's Avatar
Default Re: (goodOLdayz)
are you trying to just rebuild the engine in your car,or trying to build an engine that you plan on swapping into your car?If you have a helms than thats all you should need to learn how to rebuild it.And if its done the right way,there shouldnt be any problems youd run into down the road.
Old May 20, 2004 | 11:08 AM
goodOLdayz's Avatar
im plannig on building it and dropping it later on.
but would it be cheaper than just buyig a whole swap up front ?
Old May 20, 2004 | 11:15 AM
civickiller's Avatar
depending on what parts yoru actually gonna replace, and what motor you would want to buy. hard to tell which one would be cheaper, gotta let us know this information
Old May 20, 2004 | 11:21 AM
goodOLdayz's Avatar
i was considering on building a regular b162 with cam gears, skunk 2 intake manifold, and ctr cams.hasport mounts, then i/h/e, and the rest would be stock.
Old May 20, 2004 | 11:38 AM
JDMotive's Avatar
if youre not building the block,than you should have no problems with it.What registering are you talking about?
Old May 21, 2004 | 06:22 PM
goodOLdayz's Avatar
for like when you buy the whole engine you need the paper work to prove its legit...... do i need paper work when buying a block ?
Old May 23, 2004 | 08:11 AM
dwayne.eaddy's Avatar
lets say this when u give the vin # that tells everything about the car each number means something. the helms book is great i got one. if u can read u can do it i did it. here is my .02 buy the helms study it until u know it with out looking in the book and get the haynes for quick reference. if you don't have tool u r going to send a lot on tools renting them etc. it is easy man u can do it. the wiring is so simple it will pretty much lay where it goes when u put it back in.
go for it
Old May 29, 2004 | 06:01 PM
michael O's Avatar
Default Re: (fuckyou)
I think it would cost more to rebuild an engine than to just drop a complete swap in. But if you rebuild it right it should last a lot longer than some unknown mileage engine you just drop into your car. By doing basically everything the correct way on my car it cost me alot more than just dropping a swap in.
ALystrup
Oct 31, 2017 07:39 PM
Mulvert88
Honda Civic (2001 - 2005)
Jan 31, 2016 03:49 AM
Mulvert88
Dec 28, 2015 08:29 PM
92jdmx
Dec 1, 2005 05:12 PM
msinsky14
Oct 10, 2005 07:36 AM
