IDRC Pro- AM , cant run coolant????
I dont' know the rules exactly, but I don't see why that would be a rule? Coolant actually raises the boiling point of water as well, I wouldn't ever run just water.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lugnuts »</TD></TR><TR><TD CLASS="quote">Its a rule because antifreeze is 2X more slippery and harder to clean off of the racetrack</TD></TR></TABLE>
exactly... running water is just fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_Racer_DRU »</TD></TR><TR><TD CLASS="quote">
exactly... running water is just fine</TD></TR></TABLE>
Running water is fine as long as it's distilled water.
Clayton
Clayton
but isnt the water pump lubricated by coolant???
this is a street car/my daily driver , will i be ok running just water?
can i run water wetter?
Coolant is a lubricant. I would still use just a tad in the system even though they dont really want you too. Using just water will start rusting parts up. Just dont leak any on the track
Smarter than you
I used to run a single core radiator in the summer heat of texas and when I ran water only it used to boil after about 30-45 minutes... **** running water only. Coolant fixed the problem btw.
Nah, they wont check it and even if u did overheat...it wouldnt be a big deal. Its more of a curtousy with us pro racers to help keep the track running since it sucks to be suited up and waiting in a hot race car all day long.
yea coolant is a mess to clean up in a shop.. let alone at the track under those extreme conditions.. coolant/h20 mix for street driving.. h20/redline water weter for track use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">i think i might go 50/50 water and water wetter</TD></TR></TABLE>
that would be alot of water wetter.. Read the bottle and see how much you should use.. I think i didnt even use a whole bottle for my car, and i used h2o and water wetter only..
imma use all water wetter ahahah . my car would throw up. naw i think 2 bottles should do it . i want somthing thicker than water to keep things nice inside , no rust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">imma use all water wetter ahahah . my car would throw up. naw i think 2 bottles should do it . i want somthing thicker than water to keep things nice inside , no rust</TD></TR></TABLE>
if i was you i wouldnt do that but its your car,1 watterwetter is more than enough.
no car running at the track is supposed to have coolant in it, Period. Water only.
It doubles/tripples clean up efforts when spilled. There is nothing worse then waiting for a clean up when it is a coolant clean up as it is the worse and the longest of all.
We couldn't finish the bracket classes at NHRA ATCO this past weekend due to the fact that people kept dropping one fluid or another. That really sucked.
I don't mean to be a dick, just trying to educate. You asked a great question, just wanted to make sure you got the right answer. A lot of tracks do check for coolant!
While I am at it, if you experience a problem on the track pull off the line and stop safely as soon as possible just in case you are leaking anything. If you are leaking something it will lessen the clean up efforts required versus continuing down the track and the shut down area.
Water wetter is designed to not only keep the water in your coolant system from boiling over, but it also prevents corrosion / rust. using more than 1 bottle is just a waste of money..
invisible
17
May 30, 2007 09:31 PM
2SlowDC
Oct 1, 2005 08:32 PM
SPiFF
39
May 26, 2004 09:55 AM
