HELP ZC OR D16Z6
Old May 19, 2004 | 02:40 PM
DEVINEER's Avatar
Default HELP ZC OR D16Z6
I HAVE A 92 4 DR DX WITH THE 1.5 L SOHC. WITH ALMOST 200000 MILES TIME TO FRESHEN UP BUT I DONT WANT SPEND A LOT OF MONEY
I HAVE DC HEADER,AEM INTAKE,AND MAGNAFLOW EXH. I WANT TO KEEP MY BOLT ONS
I THINK A SOHC VTEC WILL BE NICE WITH THE MODS
OR MAYBE A TURBO
I WOULD LIKE TO PUT IN A DOHC ZC BECUZ ITS A GOOD MOTOR AND MY MODS WILL BOLT ON
ZC1 OR ZC 2 I HAVE
Old May 19, 2004 | 02:45 PM
h1coupe's Avatar
the dohc zc is a obd-0 engine and you have a obd-1 car, and i believe it is not a recomended swap unless you can find the rare obd-1 zc!
but there are wiser men out there then me who can put this straight!
Old May 19, 2004 | 02:53 PM
DJ_SaNdOz's Avatar
Default Re: (h1coupe)
Go with the Z6, I've had a DOHC ZC in a previous car, and while it is a good motor, I would stick w/ the newer technology designed for your chassis. It's aprox. the same power either way.
Old May 19, 2004 | 03:39 PM
suspendedHatch's Avatar
Default Re: (DJ_SaNdOz)
The DOHC D series from the early Integra is crap compared to the other motors we have available. Why would you want that?
The OBD1 ZC is rare? I got one and they didn't say anything about it being rare. Get this or a Z6, the ZC has slightly higher compression but I would get whichever is cheaper and readily available.
Old May 19, 2004 | 03:43 PM
EGinNY's Avatar
Default Re: (shaundrake)
Find yourself a low milage d16z6 at a local junkyard and throw a zex cam in there
Old May 19, 2004 | 03:51 PM
EFing_bmxED's Avatar
Default Re: HELP ZC OR D16Z6 (DEVINEER)
I've got a 94 CX with a DOHC ZC that I got off EbAY for $300. While it is a good motor, has gobs of power, it bolts right in using the your tranny and harness, and some d-series stuff bolts to it (headers, intake, ...), I wouldn't recommend buying one because it's been so hard to find the little things like a distributor. I've gotten 3 that are supposed to fit and none of them are the same as my old one. But if you're looking for a cheap & easy swap ZC is the way to go.
Old May 27, 2004 | 02:03 PM
EGinNY's Avatar
Default Re: (EGinNY)
Forgot to mention since your car is a '92 it is Pre-wired for vtec from your fire wall back. Simply purchase the motor harness with the motor (d16z6). it will plug right in and be ready to go......with a P28 computer
all this can be found at a local junkyard in any '92-95 civic EX or Si
I got my motor for 400 w/ dist. and harness,andthe computer for 100 (pics in link in sig.)
Old May 27, 2004 | 02:06 PM
EGlovr's Avatar
i would opt for the z6
Old May 27, 2004 | 02:12 PM
hYbRiD EeEkAy's Avatar
get a Z6 or a jdm d15b and run the P08 ecu with it
Old May 27, 2004 | 02:50 PM
Dlpz87's Avatar
Default Re: HELP ZC OR D16Z6 (KwikEG)
Get the z6 and for the love of God stop typing in caps. Seriously though, the z6 has a wayyyy broader aftermarket and it's more current than the ZC would be. Not to mention it has VTECHHHH!!
Old May 27, 2004 | 03:10 PM
[Caster]'s Avatar
Default Re: HELP ZC OR D16Z6 (Dlpz87)
Whilst the Z6 may have more aftermarket support I think the ZC delivery of power being much more linear would be a better option and if you were to turbo down the track would be the better one
djxtc65
Jul 26, 2006 04:54 PM
kardal86
Jul 18, 2006 06:26 PM
91hfrex
Feb 23, 2006 10:38 AM
1badrex
Dec 26, 2003 04:48 AM
bearboy80
10
Apr 3, 2003 04:28 PM
