Need Help on Changing Gauge Cluster..
Old May 19, 2004 | 11:09 AM
chinkyEyez's Avatar
Default Need Help on Changing Gauge Cluster..
in order to change Gauge Cluster.. do i need to take apart whole dash?.. i want to change gauge cluster but dont know how,,, plz help me
Old May 19, 2004 | 11:23 AM
CRITTERMATT's Avatar
Default Re: Need Help on Changing Gauge Cluster.. (*****yEyez)
At the top of the cluster there are two screws. take them out and pull the bezel toward you. once the bezel is removed there are 4 screws holding the cluster in. romove these and the cluster will come out.
These dircetions are for a 96-2000 civic, any other model I do not know.
Old May 19, 2004 | 11:24 AM
chinkyEyez's Avatar
Default Re: Need Help on Changing Gauge Cluster.. (CRITTERMATT)
Thx!! if i buy a cluster with techometer can i hook it up right away even thou i had none in my old one??
Old May 19, 2004 | 11:28 AM
Yes it should be plug and play. But dont hold me to it. Everything else should work but you might have to wire the tach up. It doesn't take but a few minutes to find out. It only takes a few minutes to get the cluster out.
Old May 19, 2004 | 11:32 AM
chinkyEyez's Avatar
thx!!!! you are my HERO..lolz
Old May 19, 2004 | 12:05 PM
Daniel_san's Avatar
don't forget the screw behind the hazard botton
you need to pop it out, to get to the screw
Old May 19, 2004 | 12:06 PM
Ricey McRicerton's Avatar
Default Re: Need Help on Changing Gauge Cluster.. (Daniel_san)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel_san &raquo;</TD></TR><TR><TD CLASS="quote">don't forget the screw behind the hazard botton
you need to pop it out, to get to the screw</TD></TR></TABLE>
Not for an EK.
He's got both according to the sig.
Old May 19, 2004 | 12:14 PM
NickW's Avatar
Default Re: Need Help on Changing Gauge Cluster.. (Ricey McRicerton)
I just got done with a cluster swap in a 92 vx, no tach POS. We swapped in a SiR cluster with a tach and all worked fine, plug'n'play is nice, no wiring needed at all.
It should take less then 30 minutes for this install.
Old May 19, 2004 | 03:39 PM
chinkyEyez's Avatar
Default Re: Need Help on Changing Gauge Cluster.. (NickW)
thx everyone
now just need to find a decent gauge cluster
Old May 19, 2004 | 07:17 PM
akaba's Avatar
i have a 5spd 00 ex cluster for sale. it has 42k ac technic indiglows (but you can take those off) and a blue bezel
Old May 20, 2004 | 09:36 AM
chinkyEyez's Avatar
Default Re: Need Help on Changing Gauge Cluster.. (ask_611)
how much and where you at?
Old May 21, 2004 | 01:51 PM
akaba's Avatar
85 and i am in houston
carlitos3155
Aug 11, 2011 08:07 AM
twedter02
Sep 24, 2010 10:00 PM
ShoStopR
Sep 26, 2007 06:22 PM
RC211V
Honda Motorcycles
Oct 1, 2005 12:37 PM
