300whp+ sohct 4 door civic
1997 EJ6 Honda Civic LX SOHC-T
Performance:
Daily driven & raced, 2,350lb curb weight, 347whp and 270ft-lbs at 20.7 psi on dynojet chassis dyno tuned by dynotech motor sports, 12.83 @ 115mph in quarter mile, 29 mpg, 160k+ miles
Engine & Transmission:
D16Y7 sohc non-vtec, decked, bored, blueprinted and balanced, custom Wiseco pistons (high-temp coated), Eagle H beam rods, ARP head studs and rod bolts, Balanced, polished knife-edged crank, Cometic head gasket, custom intake manifold, 94 DX throttle body, custom 3” turbo back exhaust, Apex’I N1 muffler, Apex’I AX53 B60 P18 ball bearing turbo kit, Apex’I GT front mount intercooler, Apex’I blow off valve, Spoon oil cap, Lokar dipstick, Powder coated valve cover, DEI exhaust wrap, B&M short throw shifter, Energy Suspension shift bushings, Exedy 3 puck clutch, 94 DX transmission, power steering, AC and cruise control removed
Engine Management:
Apex’I turbo timer, Apex’I S-AFC, RC 310cc injectors, AEM fuel rail, Aeromotive fuel pressure regulator, Vortech FMU, Walbro 255lph fuel pump, Turbo XS boost controller, NGK plugs
Suspension, Brakes & Wheels:
Apex’I WS full coilovers, stock front sway bar, Neuspeed front strut bar, Neuspeed rear lower tie bar, Neuspeed rear sway bar, custom camber kit, Energy Suspension master bushing set, Brembo cross drilled & slotted rotors, Akebono ceramic pads, Team Loco 144 17X7 wheels (painted gunmetal), Yokohama AVS ES100 tires 205/40/17
Exterior:
DuPont paint OEM cyclone blue (grayish blue), Carisma carbon fiber hood, JDM headlights, JDM CTR front lip, JDM CTR rear lip, JDM CTR grill, Painted mirrors & moldings, shaved emblems
Interior:
Sparco Mugello steering wheel, Sparco harnesses, Sparco shift ****, Sparco carbon fiber pedal kit, carbon fiber e-brake, 91 CRX SI seats, Autometer phantom series boost, oil, water & egt gauges, Autometer dual pillar pod, custom door panels, OEM sunroof, OEM keyless entry, OEM 6 cd changer, Cerwin Vega 6.5in speakers
Other:
McGuire’s cleaning products, Valvoline fluids including 10W30 synthetic motor oil, 15W40 tranny fluid & maxlife coolant, Sunoco 94 street gas, VP 112 race gas
almost all the work was done by myself. painted the car myself almost 3 years ago. has been making 300whp for almost 3 years, stock head with 160k+miles
Modified by sohcT at 2:25 PM 5/19/2004
Performance:
Engine Management:
Exterior:
Interior:
Other:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcT »</TD></TR><TR><TD CLASS="quote">wtf i can see them, just a little small</TD></TR></TABLE>
I can see them now. Any set-up info?
yup definately apexi kit, nice *** torque numbers... go d series
pretty much was my same exact setup way back when....ah back in the days
one suggestion would be ditch the fmu though, with so many options (free ones at that) nowadays i don't see a reason for any serious setup to use these things.
Im not sure but this turbo is supposed to max out at like 250 whp ... and how did you do to get a 11.0 ;1 AF with 310 cc injectors ??? Im not flaming you but just trying to understand the miracle behind this car loll
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo »</TD></TR><TR><TD CLASS="quote">Im not sure but this turbo is supposed to max out at like 250 whp ... and how did you do to get a 11.0 ;1 AF with 310 cc injectors ??? Im not flaming you but just trying to understand the miracle behind this car loll</TD></TR></TABLE>
Im asking the same thing as this guy.....300 hp with 310cc injectors.
Something isnt right???????
BTW, thats one of the cleanest FO DOO's ive seen
Jon
Something isnt right???????BTW, thats one of the cleanest FO DOO's ive seen
Jon
HAHAHAHAHAHAHAHAHAHAHAHAHAHA.
You know what it is is that FMU putting 3 million lbs of pressure into the fuel rail
But seriously I would upgrade to Hondata or AEM EMS....you good very well see a hp increase with proper fuel management.
This should be your future upgrade.
-Bigger injectors
-ditch the FMU
-Hondata or AEM EMS
Jon
-Bigger injectors
-ditch the FMU
-Hondata or AEM EMS
Jon
turbo must be enough doesn't roll over what so ever, ii talked to some people at apexi they said 325whp not problem with good tuning. its made 347 on race gas
