has any 1 used jb weld
Old May 19, 2004 | 08:12 AM
h23 milano red's Avatar
From: south grand prairie aka the pits of saburbian hell, tx, usa
Default has any 1 used jb weld
I have a crack in my radiator and i picked up some jb weld. I was just wondering if any 1 has used it and if so , can you give some feed back.
Old May 19, 2004 | 08:29 AM
94vtecmn's Avatar
Default Re: has any 1 used jb weld (h23 milano red)
Don't bother, replace the radiator. I tried that stuff and it lasted about 3 days.
Old May 19, 2004 | 08:40 AM
Nikoli's Avatar
Default Re: has any 1 used jb weld (94vtecmn)
i have tried it and it didnt work. if it works for you then i guess your ok, temporarily. i wouldnt call it a long term solution though. best bet is to just get a new one asap. i literally just ordered one from here http://www.radiatorexpress.com/part_lookup.asp they have an all aluminum rad. for $134.00 which is a very good deal.
Old May 19, 2004 | 09:26 AM
PrecisionH23a's Avatar
It worked for me just fine on my fluidyne for about 2 months, and even then I didnt encounter a problem. Keep in mind, it was a tiny tiny tiny pin-sized hole and I later had it re-tigged. Desperate times call for desperate measures.
Old May 19, 2004 | 09:39 AM
ViZ's Avatar
ViZ
for mild leaks i have used aluma-seal (little at a time so you dont clog it) and its worked well but if its bigger then its worth a try i suppose
Old May 19, 2004 | 10:42 AM
thehondaguru's Avatar
Default Re: (ViZ)
I used jb weld on my cracked block for 6 months and it worked pretty good for the hassle it saved me!
Old May 19, 2004 | 10:49 AM
ludelvr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtecmn &raquo;</TD></TR><TR><TD CLASS="quote">Don't bother, replace the radiator. I tried that stuff and it lasted about 3 days.</TD></TR></TABLE>
Are you serious? You must have used incorrectly, because mine lasted about a week!! hahaha, yah, seriously man, get rid of your rad, don't even bother. I went through about 4 packs of that stuff until I clued in! haha, so yah, get a new or used rad. From my personal experiences, JB weld doesn't work that well with liquid stuff. I used it on Intercoolers and it held really well! mind you I'm not boosting double digits!
Old May 19, 2004 | 10:54 AM
ludelvr's Avatar
Default Re: has any 1 used jb weld (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">It worked for me just fine on my fluidyne for about 2 months, and even then I didnt encounter a problem. Keep in mind, it was a tiny tiny tiny pin-sized hole and I later had it re-tigged. Desperate times call for desperate measures.</TD></TR></TABLE>
haha my crack was about 10" long across the top in the plastic and I'd be driving suddenly I would see droplets of water on my windshield as if it were raining!! haha, but with that I'd smell the coolant!!
O16581724 5 2 5
Welding / Fabrication
23
Dec 7, 2005 09:01 PM
ATS*Mark
Jul 19, 2004 03:02 PM
dingusjt
Feb 15, 2004 01:54 PM
JDM_ITR
Apr 25, 2002 11:56 AM
vtec_outlaw
Dec 2, 2001 08:49 PM
