oil problem
Old May 19, 2004 | 07:36 AM
slowpokesi's Avatar
Default oil problem
ive just recently noticed that the upper portion of my header (where it connects to the head, there seems to be quite a bit of oil build up on the header,
what is wrong with my car
http://www.imagestation.com/my...bum=1
Old May 19, 2004 | 07:37 AM
slowpokesi's Avatar
Default Re: oil problem (slowpokesi)
its like this on all 4 ports, the other picture didnt come out.
Old May 19, 2004 | 12:45 PM
slowpokesi's Avatar
bump,
are the pictures working?
Old May 19, 2004 | 01:43 PM
Blaze45's Avatar
Brrraaaap!
BUMP cause my B20 has the exact same issue accpet that there is more of it. I did a cmopression test and the motor seemed healthy. 180+ across all 4. tia
Blaze
Old May 19, 2004 | 03:27 PM
RCautoworks's Avatar
Are you burning oil at all, first think that comes to mind is valve seals.
Old May 19, 2004 | 04:13 PM
Blaze45's Avatar
Brrraaaap!
Default Re: oil problem (90blackcrx)
Not burning any oil here that I can tell... seems to be running fine.... Plugs are tanish brown....
Old May 19, 2004 | 05:09 PM
slowpokesi's Avatar
nope
i thought the valve seals too, but there is no smoke coming from my car, and i know what a car with bad seals does lol.
i have no idea where its coming from, u can tell that it isnt the valve cover because there is no oil on it
Old May 19, 2004 | 07:32 PM
Blaze45's Avatar
Brrraaaap!
You would think that it would just heat up and smoke off, whatever it is... But it never seems to no matter how hot the motor gets ... Strange...
Old May 19, 2004 | 07:52 PM
slowpokesi's Avatar
Default Re: oil problem (Blaze45)
exactly,
thats why i want to figure it out, it makes no sense.
Old May 19, 2004 | 08:20 PM
Redline130's Avatar
You sure you're valve cover gasket isn't leaking a bit of oil somewhere?
Old May 21, 2004 | 06:56 PM
Blaze45's Avatar
Brrraaaap!
Default Re: oil problem (Redline130)
My valvecover is not leaking anything. Its a new gasket n I used Hondabond on it. It really doesnt make any sense whatsoever because it should just burn off... Only it doesnt.
Blaze
Old May 21, 2004 | 07:20 PM
deftones0817's Avatar
I saw something about this in the all motor forum. Go ask in there I'm sure they will be able to answer that question.
DEF
jizzer671
Apr 23, 2007 05:58 PM
SPRLude
Apr 6, 2006 08:18 PM
Edward
Mar 1, 2005 09:32 PM
1 Cam Wonder
Dec 14, 2004 12:59 PM
JumboJoe
Nov 18, 2003 12:28 PM
