b16 and a6 ecu
Old May 19, 2004 | 06:10 AM
wpgcivic's Avatar
Default b16 and a6 ecu
would this cause anything having a a6 ecu with a b16 engine? i am running this because i dont have vtec, knock, o2, oil pressure lines hooked up yet?
Old May 19, 2004 | 07:20 AM
mmuller's Avatar
Mad Scientist
Default Re: b16 and a6 ecu (wpgcivic)
it would cause your engine to run very lean and timing will be way off
Old May 19, 2004 | 11:21 AM
wpgcivic's Avatar
would it effect idle at all?
Old May 19, 2004 | 12:16 PM
I3ackfire's Avatar
Default Re: (wpgcivic)
Of course it will affect idle.
Old May 19, 2004 | 01:16 PM
wpgcivic's Avatar
well then maybe i'll drop in the b18 one or else the b16 one, but can i put the b16 one in if i dont have vtec, knock, or o2 hooked up?
Old May 19, 2004 | 03:44 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">well then maybe i'll drop in the b18 one or else the b16 one, but can i put the b16 one in if i dont have vtec, knock, or o2 hooked up?</TD></TR></TABLE>
*scratches head*
whats your goal with this?
are you having trouble finding a B16A ecu for your engine? or are you worried about driving around with an A6 (PM6) ecu until you find a B16 ecu? cuz if thats the case, you CAN use the PM6 ecu on the B16 to get around.
Old May 19, 2004 | 05:06 PM
wpgcivic's Avatar
yeah well ive got a b16 ecu but i still am waiting for a buddy to come over and finish off the wiring on the car, the 4 wires needed for the b16...and i have no clue how to do it myself, unless someone has a good link
Old May 19, 2004 | 06:56 PM
Joseph Davis's Avatar
Dunno that you're comfortable soldering, but you can add components to the 90-91 PM6 ECU, or find a 90-91 PS9 out of an automatic Civic EX, and have onbe wire VTEC much like ZDyne offers. You can probably get chip burner, chipping supplies, and a PS9 or the small parts needed for your PM6 (if it's 90-91 and chippable) for the $150 a PR3/PW0 runs.
http://www.turboedit.org has the freeware tuner you'd need. I'm happy to answer any questions you have, if you're interested.
Old May 19, 2004 | 07:00 PM
wpgcivic's Avatar
or if you look closely at my last post you would see that i said i have a pr3
efkilla
Mar 21, 2011 11:34 AM
themex77
Jun 13, 2007 08:54 PM
wpgcivic
May 19, 2004 11:27 AM
89EF9
Dec 2, 2002 12:41 PM
