91 Civic Si Smokes bad!
Old May 18, 2004 | 11:21 PM
hardcorelolo's Avatar
Default 91 Civic Si Smokes bad!
Hi all, i recently bought a 1991 civic si and when i start it up, it starts smoking white and when u give it more throtel it smokes even more and it doesnt go away...also water keeps coming out of the mufler and it wont stop! can anyone figure out this prob? thanks all
Old May 18, 2004 | 11:46 PM
payneth's Avatar
Default Re: 91 Civic Si Smokes bad! (hardcorelolo)
head gasket is F*ING toast i believe. white smoke usually means that if i remember correctly
Old May 19, 2004 | 12:15 AM
mr. carpenter's Avatar
Default Re: 91 Civic Si Smokes bad! (Payneth)
run some b12 or some sort of evaporative fuel cleaner through it. replace fuel filter, drain gas. check all this if it's still smokin you've probably got a problem
Old May 19, 2004 | 01:10 AM
civickiller's Avatar
Default Re: 91 Civic Si Smokes bad! (mr. carpenter)
is this when it first warms up, or all the time ?
Old May 19, 2004 | 04:30 AM
crx_88_si's Avatar
does the exhaust smell sweet?
Old May 19, 2004 | 09:00 AM
Big Bird's Avatar
Default Re: (crx_88_si)
sounds exactly like my old zc. Bought it in the cold and it smoked white, didnt think anything of it. Over the next couple days I noticed it would smoke this semi thick/dense white smoke. Check your radiator, if its bubbling thats usually another sign of head gasket. I had both symptoms, replaced head gasket and all was well.
20mph
Sep 30, 2015 07:42 PM
DEPintheCurve
Jul 15, 2013 12:07 AM
Clash0901
12
Jun 6, 2010 01:36 PM
caliEG2dr
May 15, 2010 12:44 AM
xnvb
10
Feb 16, 2009 12:54 PM
