climate control and radio bezel removal HELP!!! 99-00si
the trim around the entire climate control and the cd player, how does that come off? i found some clips at the top that seem to pop off, but i cant get the bottom? what do i now? help and pics are appreciated if you got em.
take off the kick panel on the drivers side, glove box, console, 12v thing under the climate control, then you can get it out
Dont worry about taking your console out. Take the panel that is under the steering wheel(covering the fuse panel) out, then the glove box down and then the center. Once you take off the center plastic where the power outlet is look up in there. Should be like 4 screws that go straight up into it to hold it in.
1 speedstar
Feb 19, 2005 03:28 PM
GReddy SI
Jul 31, 2003 09:33 PM
whitemike1644
Apr 18, 2003 10:01 PM
