Will a obd1 map sensor work in a obd2 car??
Old May 18, 2004 | 09:33 PM
JdmIntegra98's Avatar
Default Will a obd1 map sensor work in a obd2 car??
i need solid truth not a guess.. only post if you know.. its important.. thanks
Old May 18, 2004 | 10:21 PM
Whitfield Inc.'s Avatar
Default Re: Will a obd1 map sensor work in a obd2 car?? (JdmIntegra98)
A map sensor from any say 92 - 95 cvc will work on say any 96 - 00 cvc for sure. We have alot of extra map sensor's around the shop and we use them on all different cars and years and have never had a problem. The part #'s are evn the same.
P.S. I just used those two years as an example - not to say they are the only two that work together - sorry
Old May 19, 2004 | 10:00 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Will a obd1 map sensor work in a obd2 car?? (RageDzine)
there is no difeerence between an obd1 and obd2 map sensor
Old May 19, 2004 | 11:51 AM
kur0ryu's Avatar
Default Re: Will a obd1 map sensor work in a obd2 car?? (HOOKUPS)
I'm using a OBD0 firewall mounted map for my OBD1 setup, so I guess all should work.
Spoon-ITR-
Mar 12, 2007 11:09 PM
dek1mfk
Nov 7, 2006 07:39 AM
menappi
Jul 2, 2006 06:31 PM
SiMateoAko
Mar 23, 2006 08:22 PM
