94' integra tie rod (drivers side) HELP
Old May 18, 2004 | 08:32 PM
94integGS-R's Avatar
Default 94' integra tie rod (drivers side) HELP
drivers side tie rod loose, tried to tighten but just spins?, do i need a impact tool to tighten it? please Help.
Old May 19, 2004 | 04:09 AM
JimBlake's Avatar
Default Re: 94' integra tie rod (drivers side) HELP (94integGS-R)
Is there a screwdriver slot in the end of the stud? (Sometimes there is.) I've gotten them in by simply squeezing it together hard while I tighten the nut. Otherwise, hold it together with channel-lock pliers or something.
Old May 19, 2004 | 06:52 AM
R6E6I6D's Avatar
Default Re: 94' integra tie rod (JimBlake)
DO NOT grab it with channel locks ....Sorry bro,( ive seen this happen too many times ) but this could rip the rubber dust guard and then its time to buy a new one... but yeah you are probebly going to need a impact tool.. Q:are they after market>?? W/the grease fitings>?
Old May 19, 2004 | 07:30 AM
JimBlake's Avatar
Default Re: 94' integra tie rod (R6E6I6D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6E6I6D &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT grab it with channel locks ....Sorry bro,( ive seen this happen too many times ) but this could rip the rubber dust guard ...</TD></TR></TABLE>Yeah, don't mangle the rubber boot. I should have explained it better. I've used channel locks to squeeze the tie rod down to the arm of the steering knuckle, so the taper pin is pressed tightly into its socket.
Old May 19, 2004 | 09:03 AM
Arsenal's Avatar
Get someone to push down on the tie rod by the bushing, then tighten
Old May 19, 2004 | 01:16 PM
vtecn8ive's Avatar
Default Re: 94' integra tie rod (Arsenal)
does anyone know if outter tie rod ends are interchangable between integras and civics.
Iuse2brk@msn.com
Old May 19, 2004 | 05:13 PM
Arsenal's Avatar
Default Re: 94' integra tie rod (vtecn8ive)
Yes they are, I put Integra tierods on a Civic steering rack.
ImaHondaLover
Suspension & Brakes
Apr 30, 2008 03:19 PM
FalkenSiR
10
Sep 5, 2006 08:54 AM
BrokenRex
10
Jan 20, 2006 12:06 AM
AJxr
13
Oct 7, 2005 05:54 PM
SoOHiGH
Jul 13, 2005 05:49 PM
