LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!!
Old May 18, 2004 | 08:28 PM
mkim12180's Avatar
Default LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!!
I recently got a ls vtec swap installed on my 99 hatch. It pulls but not as hard as my friends crx with a b17 swap. Seems my vtec isn't crossing over, top end is way underpowered compared to my friends. Could my CEL be the reason for this or what????????
Old May 18, 2004 | 08:32 PM
Redline130's Avatar
Default Re: LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!! (EK9InSPiReD)
Possibly, what is the code?
Old May 19, 2004 | 07:25 AM
b20_ed's Avatar
Default Re: LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!! (Redline130)
bump cause I would like to know too
Old May 19, 2004 | 12:27 PM
doublejz's Avatar
Default Re: LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!! (b20_EK)
pull the code, can you even hear vtec even kickin in
Old May 19, 2004 | 06:43 PM
mkim12180's Avatar
Default Re: LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!! (doublejz)
nope, i can't hear smack, haha it pulls hard to 6-7k i hear lil something, how do i pull the code????????
thanks for the replies so far guys
Old May 20, 2004 | 04:03 AM
mkim12180's Avatar
bump
Old May 20, 2004 | 06:13 AM
Cornwhiskey's Avatar
t ry switching the two wires at the oil pressure switch i had the same problem and switched the ground and the wire that goes to the ecu and it fixed it...
Old May 20, 2004 | 07:21 AM
b18cx's Avatar
Default Re: LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!! (onefastcrx88)
Go get a service manuel form autozone ($20) look up on how to pull the code, then let us know. Yes Your CEL is part of the reason your VTEC does not work. Its trying to tell you what to fix.
Old May 20, 2004 | 02:51 PM
mkim12180's Avatar
Default Re: LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!! (b18cx)
thanks for all the replies guys
Old May 20, 2004 | 05:04 PM
Used2beAb16's Avatar
ok this might be stupid but do u have enough oil pressure?? You do have an oil line to the head right? If u dont have enough oil pressure vtec will never come on.
Old May 21, 2004 | 04:35 AM
mkim12180's Avatar
Default Re: LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!! (Used2beAb16)
i have an oil feed line if that's what your referring to.
Old May 21, 2004 | 11:04 AM
Cractos's Avatar
Your friend is in a Crx....He will always seem like he is faster
Old Jun 3, 2004 | 04:20 AM
mkim12180's Avatar
Default Re: LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!! (Cractos)
it's the secondary o2 sensor, I think i'm getting one fabricated this weekend, I believe this is the problem, the CEL is keeping the vtec from crossing over since I have a obd 2 car, i'm guessing it's some sort of strict emissions control.
NVMYDC
Aug 10, 2009 02:14 PM
racereaper7
Aug 14, 2007 08:56 AM
wrx'n you
Feb 3, 2007 01:07 AM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
AllMotorB
Jul 1, 2005 08:22 PM
