how do i short shift my shift knob?
well like the topic says... i have a 2004 civic ex, with stock shifter.. ( leather 5 spd ) how do i short shift it.. where do i have to shave it ? and how do i take it off?
thx in advance
thx in advance
Whew....okay here we go.
A short shifter actually replaces your shifter, not just your shift ****.
I don't know anything about the 02+s but on the 92-00s the shift **** just screwed off.
i believe they are the same on the 04's but if not like the s2000 there is a nut on the shifter that you must loosen then just unscrew the rest of the ****, pretty easy. as for shortening the shift like said above, there is more tehn just shaving the ****.
i want to short shift mine... as in like makin the shifter it self shorter.. thast all not a whole short shift kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exclusive_vtec »</TD></TR><TR><TD CLASS="quote">i want to short shift mine... as in like makin the shifter it self shorter.. thast all not a whole short shift kit</TD></TR></TABLE>
You can take your shifter out and cut the top of it off and rethread it if that's all youre trying to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
You can take your shifter out and cut the top of it off and rethread it</TD></TR></TABLE>
You could also just get an aftermarket ****. I have a Sparco ball, and it sits much lower on the shifter than a stock ****.
Modified by OBD1Kenobe at 12:33 AM 5/19/2004
it will make your trows shorter but it will also make it harder to shift. that the whole idea behind short throw is to make both parts shorter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">it will make your trows shorter but it will also make it harder to shift. that the whole idea behind short throw is to make both parts shorter</TD></TR></TABLE>
Werd, but it doesn't sound like he cares about the throw, only having it look lower.
BTW: My ball is weighted, and it feels great! Because it sits lower on the actual shifter, the throw is shortened a bit and the weight counters the loss of leverage. The effort (if you can even call it that) required to shift is actually less than stock.
Just my .02
Just my .02
B16Jacques
Sep 20, 2008 09:15 AM
