power window from integra or lude
Old May 18, 2004 | 07:39 PM
sit220's Avatar
Default power window from integra or lude
i would like to know if power window from an 90 93 integra or 88 91 lude will fit a crx
Old May 18, 2004 | 08:12 PM
sit220's Avatar
Default Re: power window from integra or lude (sit220)
b
u
m
p
Old May 18, 2004 | 08:38 PM
emotionisdead's Avatar
Very Emergency!!
Not sure if the preludes or the intergras will fit, but i know the jdm power windows for the crx fit perfect. I have them and they work beutifully.
Old May 19, 2004 | 08:33 AM
nautica_t's Avatar
Default Re: power window from integra or lude (SpoonDC2R)
picture doesn't work...
i have usdm power windows :D
Old May 19, 2004 | 11:30 AM
sit220's Avatar
bump
Old May 19, 2004 | 11:54 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
i still would like to know if tey work from a prelude. but they do work from the 88-91 4door civics with power windows.
Old May 19, 2004 | 12:06 PM
crexer's Avatar
Default Re: (91siredrex)
The 4 door ef's power windows are compatible with crx's? Wow i want to know more
Old May 19, 2004 | 12:08 PM
I3ackfire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonDC2R &raquo;</TD></TR><TR><TD CLASS="quote">Not sure if the preludes or the intergras will fit, but i know the jdm power windows for the crx fit perfect. I have them and they work beutifully.</TD></TR></TABLE>
Well its only common sense that the Crx JDM windows would work in the USDM ones...
Old May 20, 2004 | 10:00 PM
sit220's Avatar
bump for more info
Old Jun 1, 2004 | 08:54 PM
derekellison's Avatar
90-93 will work but you half to take the top track out of the crx and put it on the integra setup. and the bottom mount will need two holes drilled out for the bolts to go through. i have them in mine i know for a fact they work hollar at me if you need some more info
USNneverAGAIN07
27
Mar 7, 2010 06:56 PM
luciffer
Mar 3, 2006 03:19 PM
EKCRX-Ihadastupidusername
13
Nov 22, 2005 08:43 PM
