Need help with distributor swap
Old May 18, 2004 | 06:52 PM
WuRKD b16's Avatar
Default Need help with distributor swap
I just replaced my distributor with a brand new one from distributor king. Im using a single cam harness from an ex cuz my car was originally an ex now have b16. So i had to cut the dizzy harness to use the single cam plug so it plugs into the ex harness and now i have a CEL and my tach is retarded it jumps and when i punch it, it doesnt even move. Anyone know wats wrong?
Old May 19, 2004 | 12:50 PM
WuRKD b16's Avatar
Default Re: Need help with distributor swap (WuRKD b16)
anybody???
Old May 19, 2004 | 02:29 PM
Ekasey's Avatar
you need to rechceck your wiring my guess is it is porbably TDC or crank position code that means thats not wired right and it is porbably the blue orange wire
Old May 19, 2004 | 04:23 PM
WuRKD b16's Avatar
Default Re: Need help with distributor swap (eLusive ek4)
thanks where should the blue orange wire go?
Old May 20, 2004 | 10:47 AM
WuRKD b16's Avatar
does anyone have a diagram for wiring a gsr distributor to a single cam plug?
Old May 20, 2004 | 11:15 AM
Ekasey's Avatar
it needs to go to the corresponding pin on the ecu not sure which one unfortunatley
GetawayInMoscow
Jun 24, 2009 03:07 PM
talonturbotsi94
Aug 18, 2007 05:23 PM
hondab16tuner
Dec 14, 2006 08:41 PM
