What kind of pump gas are you putting in your Stock JDM swap?
Old May 18, 2004 | 06:31 PM
ramz7887's Avatar
Default What kind of pump gas are you putting in your Stock JDM swap?
Would you put in 93 oct? or could you get away with 87
Old May 18, 2004 | 09:56 PM
Kamin's Avatar
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (ramz7887)
run premium.
Old May 19, 2004 | 12:46 AM
MPower332TI's Avatar
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (Kamin)
Run the highest octane you can get your hands on. 93 all the way and i would even add some octane booster every now and then just to keep it clean. You will have alot of pinging (detonation) if you run 89 or lower, also bad perfromance.
Old May 19, 2004 | 12:43 PM
paybac4223's Avatar
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (jDmDxTuRd)
91 in cali yo! so i add 1 cup of 108 race fuel to my tank after every fill up
Old May 19, 2004 | 02:54 PM
ramz7887's Avatar
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (paybac4223)
what are the gas prices like in cali? Here in ky their 2.00
Old May 19, 2004 | 03:57 PM
93preludeh22's Avatar
2.11 in MD
Old May 19, 2004 | 05:59 PM
Hondaaccordvtec's Avatar
Default Re: (93preludeh22)
$2.29 in Ma. for premium
Old May 19, 2004 | 08:40 PM
Ryan C's Avatar
Default Re: (Hondaaccordvtec)
what he said ^^
Old May 19, 2004 | 09:32 PM
AzNpRiD3's Avatar
Default Re: (Ryan C)
2.53 now in cali
Old May 19, 2004 | 09:54 PM
jmk2888's Avatar
$2.69 in L.A.\\
Old May 20, 2004 | 05:13 AM
ShakesTheKlown's Avatar
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (jmk2888)
2.75 on maui for 92 octane, and it's the only thing I put in my car...
Question, do ALL jdm swaps require high octane? What about jdm d16's? B series aren't the only jdm swaps out there...
Old May 20, 2004 | 05:15 AM
VTECVillain's Avatar
$2.30 for 93 here in WV
Old May 20, 2004 | 06:41 AM
DA6righthand's Avatar
i never run that 87 gas/water. its not the best on the motor. and especially since the c5 has high comp, you might get some knockin and pingin if you run low octane. so i suggest 93. its worth the money. gas is on the ries tho, 2.19 for 89-90 octane here in cincy ohio.
Old May 20, 2004 | 07:00 AM
ki3t's Avatar
This user can set his title.
Only 93 premium will touch my B18C coupe. $2.18 so far.
Old May 20, 2004 | 07:09 AM
jspekter7's Avatar
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (Ki3t)
I run 93 octane at all times in my Honda, from the old swap to the new one, but I also have a chipped ECU so it's fairly necessary, but now that I think about it, gas is different in the land of the rising sun, they are used to running on higher octane, I believe that 91 is their low grade and 95 may be the high (never been there just seems I've heard this).
Old May 20, 2004 | 07:46 AM
showtymers619's Avatar
* B A N N E D *
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (jspekter7)
lol wanna kno what happends to a b16 on 89 octane? .. you cant get pass 60mph no matter how wide oopen your throttle is i accidently done this WAY bay... like 4 5 years ago...i had to dump like a few bottles of octane booster.. for it to run normal again
Old May 20, 2004 | 08:04 AM
FATBOYeg6's Avatar
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (ShowTymers619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 &raquo;</TD></TR><TR><TD CLASS="quote">lol wanna kno what happends to a b16 on 89 octane? .. you cant get pass 60mph no matter how wide oopen your throttle is i accidently done this WAY bay... like 4 5 years ago...i had to dump like a few bottles of octane booster.. for it to run normal again</TD></TR></TABLE>
that couldn't have been the gas. my friend has a b16 swap and runs it on 87. runs fine. i have another friend that has a gsr swap and runs it on 89. personally i put 89 in to my stock vx just because no matter what car i had it always saw at least 89. once i am swapped though, i do plan on running 93, but only because i will be boosting in the future.
Old May 20, 2004 | 08:14 AM
monicle's Avatar
Default Re: What kind of pump gas are you putting in your Stock JDM swap? (ninefivehatch)
swapped and turbo and 89 has no problems on the motor getting ready to go on 2 years.
Old May 20, 2004 | 08:25 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninefivehatch &raquo;</TD></TR><TR><TD CLASS="quote">
that couldn't have been the gas. my friend has a b16 swap and runs it on 87. runs fine. i have another friend that has a gsr swap and runs it on 89. personally i put 89 in to my stock vx just because no matter what car i had it always saw at least 89. once i am swapped though, i do plan on running 93, but only because i will be boosting in the future.</TD></TR></TABLE>
how do you figure it wasnt once i put like 4 bottles of octane booster it was fine? i dont see how your gonna tell me no its not that ...and yea your friend is really smart for running 87 in his b16 i bet you he will notice a night and day difference when he goes to premium octane
Old May 20, 2004 | 10:33 AM
jspekter7's Avatar
how do you figure it wasnt once i put like 4 bottles of octane booster it was fine? i dont see how your gonna tell me no its not that ...and yea your friend is really smart for running 87 in his b16 i bet you he will notice a night and day difference when he goes to premium octane</TD></TR></TABLE>
I've seen many people run b16's b18c's and such on low octane, most engines are fine with this fuel, some engines may get cranky over it, it's just hard to say.
Old May 22, 2004 | 08:26 PM
B16Civic93's Avatar
i just paid 2.21 for 94 sunoco in md, first time i ever tried sunoco 94 i usually use crown 93 but it seems to like the 94 i think i might have to stick with it for now depending on how expensive this **** gets
Old May 22, 2004 | 10:43 PM
buckNasty's Avatar
Default Re: (B16Civic93)
2.25 for 87 at the local cheap gas station
its called CA is taking it up the A$$ for GA$
Old May 23, 2004 | 05:07 AM
I use 93 octane from sunoco every 2 fillups then I use 94 on the 3rd. The 94 has fuel injector cleaner in it.. Don't need it every fillup
Old May 23, 2004 | 11:33 AM
jsdxhatch's Avatar
2.31 for 93 in wisconsin
It's better than 2.75, holy **** LA!
Old May 23, 2004 | 12:13 PM
AMS MIKE's Avatar
Default Re: (jsdxhatch)
103 octane thanks to VP Fuel's
