what cams cams can I run with is setup?
Old May 18, 2004 | 06:18 PM
dpine's Avatar
Default what cams cams can I run with is setup?
My brother has a b16a in a 91 hatch. Before we did the motor swap we added port flow inner valve springs and skunk2 ti retainers around with stock b16a outer valve springs for down the road when he wanted to think about maybe bigger cams. Well now he wants bigger cams. my question is with that setup what cams can he run? crower stage 1's, skunk2 stage 1's, ctr's. what is the biggest he can go. also he will probably raise the rev limiter to 8500-9000 range.
thanks
Old May 18, 2004 | 07:25 PM
Ryan C's Avatar
Default Re: what cams cams can I run with is setup? (dpine)
CTR's
Old May 18, 2004 | 07:31 PM
simplestyles's Avatar
if he is down to replace the outter springs then he could run the skunk stage two. yet at the same time yes right now he could run the CTR if you could find them.
Old May 18, 2004 | 08:57 PM
Ryan C's Avatar
Default Re: what cams cams can I run with is setup? (simplestyles)
b16's dont like SKS2's
Old May 19, 2004 | 01:58 PM
dpine's Avatar
Default Re: what cams cams can I run with is setup? (Ryan C)
So what your saying is with his setup don't go any bigger than ctr cams?
Old May 19, 2004 | 02:39 PM
Ekasey's Avatar
ctr's
Old May 19, 2004 | 03:37 PM
Katman's Avatar
CTR's, Buddyclubs, skunk2 stage 1's, toda A's should all work fine with your current valvetrain setup.
<-- not familiar with the Crower cam line up.
hyrolnpimp
24
Mar 24, 2004 12:52 PM
chinners10
Apr 24, 2003 08:38 PM
JDMSI
Jan 21, 2003 02:26 PM
2k1 GSR
Sep 7, 2002 09:57 AM
