home made turbo (1st time here)
Old May 18, 2004 | 05:40 PM
Turb00HC's Avatar
Default home made turbo (1st time here)
Wuzup guyz and lady's
I really need some big time help.
I own a '00 civic ex,
I made it turbo -home made- its a IHI its a small turbo i dont really know the size of it, but it boost @ 7psi stock, i actually got it from a mazda mx-6.
i got a walbro fuel pump, b&m fuel press reg, neuspeed wires, exhaust (not straight pipe) i have the v-afc II but is not tuned...
i dont feel alot of power from the car, it has a nice boost but i realy dont now and i'm also worried that i mess up any pistons becz they are stock... when warmed up the car idles @ around 650rpm as it shows on the v-afc....is that normal?
how would i know if i damaged the pistons or how can i fine tune it so it can run smoother....please any suggestion .... oh and i am on a limited budget...
thanks
Abee
Old May 18, 2004 | 06:11 PM
Street Ghost's Avatar
Default Re: home made turbo (Turb00HC)
You should probaby get that thing on the dyno and have it tuned.
Old May 18, 2004 | 06:16 PM
Turb00HC's Avatar
Default Re: home made turbo (JDM Ninja)
i cant find one in Orlando, fl
is there any way that i can tune the v-afc by myself?
and how would i know if i messed up the engine?
thanks
Abee
Old May 18, 2004 | 06:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turb00HC &raquo;</TD></TR><TR><TD CLASS="quote">i cant find one in Orlando, fl
thanks
Abee</TD></TR></TABLE>
Check for leaks. And do a compression test.
Old May 18, 2004 | 09:02 PM
boostn420's Avatar
650 is a normal idle. You can tune the vafc with your *** dyno, you'll be fine. Just dont go negative with the fuel and you'll be ok. Start by adding a lot and then pulling some out as you see fit. Its safer to start with it too rich instead of too lean. Make sure you have good plugs and timing.
Cycocap
May 26, 2018 08:30 AM
thangnhocngheo
20
Jul 25, 2005 10:49 AM
mr. vang
Jun 28, 2005 07:55 AM
TurboBumblBee
Mar 26, 2004 11:28 AM
Edgemingsr
Jan 28, 2004 06:08 PM
