Jumping Tach!
Old May 18, 2004 | 04:18 PM
WhiteEG6's Avatar
Default Jumping Tach!
I am having some problems with my distributor. Last week my tach started to jump back and forth the symptoms of a bad igniter, so I replace the igniter and the problem remains. While IM accelerating the tach moves slightly, but under WOT it pegs quickly to 8K. Could it be anything else that I have missed? I checked all my connections. I notice that when I turn the key to the acc spot the tach moves to 1k. IM stumped here.
Old May 18, 2004 | 05:12 PM
civickiller's Avatar
Default Re: Jumping Tach! (WhiteEG6)
might have to replace the whole dist, try swap with a known good dist and see if it still happens
Old May 18, 2004 | 08:50 PM
4crx4me's Avatar
Common problem on Hondas.
Loose or corroded main ground connector at thermostat housing and/ OR Loose or corroded connections at the coil and /or ignitor inside the dizzy.
Clean, tighten, crimp and Di-electric grease all the above.
HTH
Old May 19, 2004 | 04:12 PM
WhiteEG6's Avatar
Default Re: Jumping Tach! (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">Di-electric grease all the above.
HTH</TD></TR></TABLE> Di-electric? is this a specific type of grease?
Old May 19, 2004 | 05:53 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteEG6 &raquo;</TD></TR><TR><TD CLASS="quote"> Di-electric? is this a specific type of grease?</TD></TR></TABLE>
Yeah, Permatex makes it. They sell it at pep boys. It's not absolutely neccasary, if you do the the first 3 things, though.
Old May 23, 2004 | 03:57 PM
PurpleDC2's Avatar
make sure to check the main ground, the one attached from body to the tranny
Old May 23, 2004 | 04:24 PM
NSTY Z33's Avatar
Ok, i'm sorry, but is their a pic that shows where these grounds are, or a more brief description, thanks!
Old May 23, 2004 | 04:56 PM
NSTY Z33's Avatar
bump!!! help!!
Old May 23, 2004 | 09:49 PM
NSTY Z33's Avatar
WhiteEG6. Found it/fixed it man, exact problem as you.
I cleaned/dremeled ground plate and grounds at tranny/chassis.
Tighted up connectors at ignitor(Would have rather soldered, but don't have tool)
Brushed up all connectors at ignitor and coil.
This all helped, thanks to people's posts. Hopefully problem does not arise again till i get my new motor in
Old May 25, 2004 | 09:51 AM
speedDOHCtors's Avatar
Default Re: Jumping Tach! (JDMCRXDelSol)
Open the distributor and make sure that all of your connections are really tight. It seems that if they are even the slightest bit loose it will cause the tach to jump. Also make sure to check the back of the speedo. It's possible that a wire could have come loose in there also.
lexusgui
Jul 27, 2008 07:54 PM
soad1234
Aug 19, 2007 01:45 PM
crxb16ftw
Jun 20, 2007 12:02 PM
sit220
Jun 13, 2004 04:07 PM
WhiteEG6
May 20, 2004 03:57 AM
