Ok, used bare block, what to do next?????
Old Nov 7, 2001 | 10:57 AM
myNAteq's Avatar
New User
Default Ok, used bare block, what to do next?????
I have a used b16 block and I'm going to throw in new CTR pistons. Do I need to rehone the block or what? Balance the crank? The block is in normal condition.
Thanks
Old Nov 7, 2001 | 11:04 AM
WAFFLES's Avatar
Default Re: Ok, used bare block, what to do next????? (myNAteq)
Yes you have to hone the block. The crank should be pretty well balanced, as with most Honda cranks. I would balance the rods and pistons. And I think there's is something else you need to check out. I think there are clearance problems with the PCT pistons in a b16a. Not sure, maybe someone who has done this can back me up. But definitely balance the rods and pistons and hone the block.
Old Nov 8, 2001 | 10:23 AM
myNAteq's Avatar
New User
Default Re: Ok, used bare block, what to do next????? (WAFFLES)
Do the crank and pistons need to be out of the block to be balanced?
Old Nov 8, 2001 | 10:37 AM
rainforest's Avatar
yeah you have to mill the rod so the piston can fit on the rod. you have to mill it usually 1mm on both sides. i have heard by somebody that it is alittle more than 1mm so check it out first..
whytTypeR
Feb 8, 2005 06:42 PM
topsekret
Aug 5, 2003 08:33 PM
qqqq
Apr 28, 2003 04:41 PM
