what problems come with high compression?
Old May 18, 2004 | 03:21 PM
B3AS's Avatar
Default what problems come with high compression?
i just wanted to know some of the problems u run into with running higher comp pistons, or what precautions are needed. can i put some 11:1 pistons in my b16 and be done with the bottom end? 11.5:1?
Thanks
Old May 18, 2004 | 04:01 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: what problems come with high compression? (Love2race)
There is no problems with high compression.
Too much will just need more octane.
Old May 18, 2004 | 09:23 PM
B3AS's Avatar
Default Re: what problems come with high compression? (tommy69)
i realize it might not be a smart thing to do but your saying technically i could put some 13:1 pistons in my stock b16 as long as i ran with some high octane gas?
Old May 18, 2004 | 09:32 PM
Tadeh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Love2race &raquo;</TD></TR><TR><TD CLASS="quote">i realize it might not be a smart thing to do but your saying technically i could put some 13:1 pistons in my stock b16 as long as i ran with some high octane gas?</TD></TR></TABLE>
Tuning and higher octane fuel, yes. And yes that would be VERY stupid...^
Old May 18, 2004 | 09:48 PM
MajorPayne's Avatar
well it would be a good idea to get a better head gasket as it will have a better chance of leaking or blowing if you have higher comp, and yeah higher octane gas will def be a good idea, if you want to go really high with the comp youre going to want to do some valve train work
Old May 19, 2004 | 05:51 AM
B3AS's Avatar
Default Re: (MajorPayne)
ok, that brings me to another question, around what compression can i run on 93 comfortably. i dont want to be on the edge of something going wrong.
Old May 19, 2004 | 06:33 AM
PirateMcFred's Avatar
Default Re: (Love2race)
11:5 or a little higher would probably be fine then. Just don't push the engine until it is TUNED
Old May 19, 2004 | 07:50 AM
StyleTEG's Avatar
Default Re: (PirateMcFred)
If you don't have big enough cams, higher compression will blunt your high end power. The piston loses velocity as it heads towards TDC quicker, with higher compression.
H0NDAdAddy LS
Dec 4, 2008 06:04 PM
lsvtechatch92
Jul 18, 2007 01:51 AM
kantfadedisazn
21
Sep 17, 2006 11:10 PM
Finger Lickin' good
24
Aug 1, 2005 04:29 AM
marsvolta
15
Mar 12, 2005 09:51 AM
