oil change?
Old May 18, 2004 | 03:20 PM
ekdriven's Avatar
Default oil change?
this is kinda dumb question but how many quarts of oil do i need to change the oil in my car.. its fairly new car for me and i didnt get owners manual with it 2000 GSR . also what oil do you suggest cause im goin to store now please respond asap.
Old May 18, 2004 | 03:26 PM
greaseball's Avatar
Default Re: oil change? (deputyGSR)
castrol syntec or mobil1 10w30. 4.2 quarts. make sure it's between the 2 dots on the dip stick.
Old May 18, 2004 | 03:27 PM
ekdriven's Avatar
so get 5 to be safe?
dannylDAsport's Avatar
4-5 quart syntec oil is good. jsut put 4 first then add till its between the 2 dots in oil dip stick
2G0S0R1's Avatar
New User
4 quarts plus a bottle of 4cyl oil additive, keep an extra quart handy in case.
I recommend Castrol GTX 5 or 10w30 if your using dyno oil.
Default Re: (deputyGSR)
get 5 to save you a trip just in case,.
Old May 18, 2004 | 03:31 PM
stp_vtec_boi's Avatar
i think you need at least 5 quarts or so i think it will do it...
Old May 18, 2004 | 03:51 PM
Curtisbeef's Avatar
i allways use 4.5 quarts and that is allways more than enough
Old May 18, 2004 | 04:36 PM
xTravBx's Avatar
Default Re: (Curtisbeef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curtisbeef &raquo;</TD></TR><TR><TD CLASS="quote">i allways use 4.5 quarts and that is allways more than enough</TD></TR></TABLE>
But -more- than enough is not a good thing.
Old May 18, 2004 | 06:07 PM
alfaaay's Avatar
Default Re: (xTravBx)
I've always poored just 4 quarts in. Seems fine judging by my dip stick reading afterwards.
Old May 18, 2004 | 06:09 PM
nyo91's Avatar
4 qts is adequate
Old May 18, 2004 | 06:51 PM
supaZZZleepa's Avatar
Default Re: oil change? (nyo91)
i sell genuine honda filters if anyone needs any
Old May 18, 2004 | 08:32 PM
riceball777's Avatar
i always use 4.5 quarts and i always keep it on the higest dot
Old May 24, 2004 | 03:11 PM
Ekfoe's Avatar
Default Re: oil change? (riceball777)
im a little over the two dots........should i be worried.......how much over is too much?
Old May 24, 2004 | 03:13 PM
debogsr's Avatar
Default Re: oil change? (Ekfoe)
Owners manuel says 5w30 for the gsr, although 10w30 works
Old May 24, 2004 | 03:22 PM
ragejed's Avatar
Default Re: oil change? (2G0S0R1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2G0S0R1 &raquo;</TD></TR><TR><TD CLASS="quote">4 quarts plus a bottle of 4cyl oil additive, keep an extra quart handy in case.
I recommend Castrol GTX 5 or 10w30 if your using dyno oil.</TD></TR></TABLE>
You are not spose to use oil additives in honda engines....
Old May 24, 2004 | 05:20 PM
EL Vap133's Avatar
Do not overfill. Just check the dots on the dipstick.
powerdbygarrett
Apr 28, 2008 07:28 AM
Vouthanack
Jul 30, 2004 11:18 AM
Steve26
Jul 29, 2004 05:09 PM
RaVAGE00
Jun 2, 2003 04:29 AM
blkbeast
May 28, 2003 10:48 PM
