I dont know why I cant remember this... H23 crank in a 98+ H22 Q's????
I cant remember for the life of me... Im almost positive the mains on the 98+ blocks are 55mm and the pre 98 blocks are 50mm (right?)
****, I forgot... Help me out on this one...
What needs to be done to get the H23 crank into a 98 block???
losing brain cells everyday
You are correct about the main sizes.
I don't think you can fit an H23 crank in a 98+ block.
Why not sell your block and get a 93-97 vtec block or a 92-96 H23 block??
an h23 crank in an h22 block is pointless. the main reason why people spin bearings is because of the longer stroke ratio. you might as well just do an h23/22 vtec or just stick with a stock h22 block/crank.
:edit: not pointless but more likely to have problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95deckedlude »</TD></TR><TR><TD CLASS="quote">an h23 crank in an h22 block is pointless. the main reason why people spin bearings is because of the longer stroke ratio. you might as well just do an h23/22 vtec or just stick with a stock h22 block/crank.
:edit: not pointless but more likely to have problems</TD></TR></TABLE>
Id have to disagree, ive seen many run very strong and with plenty of reliability... The internet is about the only place Ive seen with problems pretaining to 2.3 blocks... Jeff of IB had one that ran for years with no problems, so have a ton of others... You cant always believe what you see/read on the internet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCalude98 »</TD></TR><TR><TD CLASS="quote">I cant remember for the life of me... Im almost positive the mains on the 98+ blocks are 55mm and the pre 98 blocks are 50mm (right?)
yes 98+ is 55mm
and 97 and below is 50mm
the only way to get a h23 crank in a 98+ block is to look into find an h23 crank from the h23 vtec that came in the accord sir, that was made 98+
but other than that, if you find some company that will make you 5mm main bearings .. whihc i wouldn't do..
yes 98+ is 55mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx »</TD></TR><TR><TD CLASS="quote">What about a F23 crank in a 98+ h22 block?</TD></TR></TABLE>
that works too
that works too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCalude98 »</TD></TR><TR><TD CLASS="quote">Jeff of IB had one that ran for years with no problems, so have a ton of others... You cant always believe what you see/read on the internet </TD></TR></TABLE>
You are correct sir... Many people seem to forget that not every person or shop that builds engines talks about it online... There are some badass motors out there that have been built that we will never even know about... Although an H23 VTEC seems like a rarity here on HT, people build them all the time, still not as common as the popular LS/VTEC but if you go out to your local races and meets I'm sure you will find someone with an H23 VTEC pimpin strong...
Thats what I was going to reccommend, I like the idea of 55mm mains better...
Isnt the F23 crank 98mm?
what about the mains on the 95mm F22 crank? 50? 55?
Ive seen the F22 and H23 cranks side by side and couldnt tell the 2 apart...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCalude98 »</TD></TR><TR><TD CLASS="quote">Isnt the F23 crank 98mm?
Ive seen the F22 and H23 cranks side by side and couldnt tell the 2 apart...</TD></TR></TABLE>
The F22 and H23 cransk are EXACTLY the same. They even have the same part number.
F23 -> 97mm stroke 55mm mains
f22 + h23 -> 95mm stroke 50mm mains same part number
tonylude94
Jul 25, 2003 10:02 AM
