Si/RSX head question
Old May 18, 2004 | 01:17 PM
McFly's Avatar
Default Si/RSX head question
Is the head on the Si and the RSX Type S basically the same with the exception of the rocker and cam assemblies. Could you install the rocker and cam assemblies from an RSX onto the Si head. I don't have a RSX head to compare it to.
Old May 18, 2004 | 04:46 PM
rsxmachine's Avatar
does the K20A3 head have lost-motion assemblies? if not then you're gonna need the K20A2 head... there are other things to consider too, for example the K20A2 has a higher flowing head with different valves & valvesprings
Old May 18, 2004 | 05:47 PM
Kal's Avatar
Kal
Default Re: (rsxmachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxmachine &raquo;</TD></TR><TR><TD CLASS="quote">does the K20A3 head have lost-motion assemblies? if not then you're gonna need the K20A2 head... there are other things to consider too, for example the K20A2 has a higher flowing head with different valves & valvesprings</TD></TR></TABLE>
Old May 18, 2004 | 06:17 PM
McFly's Avatar
No, there are no lost motion assemblies on this head. The reason I was asking was I have a 03 Accord head which is basically the same as the Si and I was wandering if it could be used in a performance application, with of course new valves and springs. I have never seen an RSX-S head before so I had nothing to compare to. I guess I can scrap that idea. Thanks for the info.
black99x
Sep 27, 2006 04:18 PM
Juniorhatch
Aug 28, 2006 02:45 PM
BlackThorN
Nov 13, 2005 07:15 PM
evilxkid
Jul 23, 2004 04:18 PM
