ABS light coming on after Legend brake install...anybody else have this problem?
Old May 18, 2004 | 12:45 PM
95 integra's Avatar
Default ABS light coming on after Legend brake install...anybody else have this problem?
Well my abs(surprisingly) worked perfectly until I did the legend brake upgrade...all the brakes and abs pump have been properly bled. Just wondering if anybody else had this problem with the 94-95 integras or if it just happened to go out at the same time I did the upgrade.
Old May 19, 2004 | 03:50 AM
JimBlake's Avatar
Default Re: ABS light coming on after Legend brake install...anybody else have this problem? (95 integra)
What code is it throwing?
Old May 19, 2004 | 08:23 AM
95 integra's Avatar
Default Re: ABS light coming on after Legend brake install...anybody else have this problem? (JimBlake)
code 18 - accumulator gas leak(aka big brown can).
Im not sure because I know the 94-95s are prone to the abs being busted and considering that I put in a new(used) abs unit and it throws the same code I figured its probably the "common problem" for the year, but I didnt know if the bigger brakes might have something to do with it not pressurizing properly or something.
Old May 19, 2004 | 09:16 AM
JimBlake's Avatar
Does it throw the code immediately when you start? After resetting? I'm not sure, but I think the ABS doesn't have any way to 'know' about the bigger brakes, until you lock your wheels & the ABS actually operates. I think the pump-up & self-check when you start the car is pretty much self-contained.
Old May 19, 2004 | 09:28 AM
IntEGNYC's Avatar
my 95 has ABS and never threw a code yet.
Old May 19, 2004 | 09:58 AM
garados's Avatar
my 95 abs system had that accumulator gas leak problem, so I just took out the abs light. problem solved
Old May 19, 2004 | 12:13 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Does it throw the code immediately when you start? After resetting? I'm not sure, but I think the ABS doesn't have any way to 'know' about the bigger brakes, until you lock your wheels & the ABS actually operates. I think the pump-up & self-check when you start the car is pretty much self-contained.
Sometimes it throws a code and sometimes it does. Ive reset it a few times and it still comes on. Im pretty sure that youre right about it being a self-contained unit and probably doesnt know about the "bigger brakes", I just didnt know because the ABS unit/block acts as the distribution block on our cars, so if all the fluid from the MC has to flow through it I figured a bigger brake(that holds more fluid) might throw it off if it was made for the smaller fluid capacity
Old May 19, 2004 | 01:21 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">... I just didnt know because the ABS unit/block acts as the distribution block on our cars...</TD></TR></TABLE>Yeah, but I think it just flows thru (unless you're sliding & activating the ABS).
Old May 19, 2004 | 09:16 PM
95 integra's Avatar
I dont know, I might cut into mine to see exactly how it works. Obviously it being broken/not pressurizing/whatever doesnt effect braking so it would seem pretty obvious that its a sealed/closed unit unless you engage abs. Also when you unhook the brake lines from the abs unit the fluid in the unit stays in it and doesnt drain out, so thats another point about it being a closed unit.
Old May 19, 2004 | 11:39 PM
triggerX's Avatar
Default Re: ABS light coming on after Legend brake install...anybody else have this problem? (garados)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garados &raquo;</TD></TR><TR><TD CLASS="quote">my 95 abs system had that accumulator gas leak problem, so I just took out the abs light. problem solved </TD></TR></TABLE>
Wha? You removed the ABS light from the gauge cluster and this solved your problem? Sorry buddy but its kinda like Homer Simpson cover the engine check light with a sticker.
The ABS light is on because there is a pressure leak in the ABS system. Check if there are leaks. If so then rememdy the problem.
Old May 20, 2004 | 03:31 AM
garados's Avatar
Default Re: ABS light coming on after Legend brake install...anybody else have this problem? (Jgears)
hahaha, taking out the bulb was the solution for me. There weren't any leaks, I had cured the problem of the abs unit sounding like a dinosaur upon startup, and I haven't had any problems with actual braking, so I haven't taken any more time to fix the problem. If further problems arise because of teh abs, I'll fix it. until then, I'll be like Homer
TyTheDAguy
Sep 23, 2016 07:52 PM
basmasta7
Mar 31, 2010 06:54 AM
urosch
Jul 18, 2007 01:35 PM
96integraGSR
Dec 27, 2005 03:27 PM
