4 wire o2 what goes where
i switced my lsvtec crx over to obd1 and i was wondering how to hook up the 4 wire o2 what color goes where my conversion harness only has one extra wire for the heated 02.
i have a 2 black 1 green and 1 white
and also it keeps on throwing a tps code i have changed the tps but still throws the code i was told by someone u was suppsoed to switch 2 wires around is this true..
thanks
thanks
wondering the same thing about the 4-wire o2. with the tps, try resetting the ecu (pull hazard fuse) if you havent already done so. thats all i can think of.
4 wire O2
black=connect to switched power
black & green=splice together and connect to ground
white=O2 sensor lead wire, connect to ecu
civicguy395
Oct 30, 2012 03:52 PM
the.hamburglar
May 3, 2006 08:11 AM
elmalouno
11
Aug 18, 2004 09:06 AM
