gonna swap need a quick answer
Just find a bseries transmission. Is your civic a bseries? If so it will fit the motor. Some modification to the mounts might be needed also, you will need a manual ecu, and shift linkage, and the clutch pedal and what not. hope this helps.
Also i didnt really read you full post. EVEN if the motor came FROM A AUTO car, it doenst matter, the tranny is what considers manual or auto not the motor, the motor will bolt up to either manual or auto.
Modified by vietguy at 2:33 PM 5/18/2004
I would also go with a cable tranny out of a 90 to 93 intregra that way u can adjust ur clutch line . U also dont have to mount the hydralic resevoir on the fire wall
danwants2btheman
Sep 13, 2006 12:33 PM
RockLee`
15
Aug 25, 2005 05:23 PM
moosepoop21
Jun 13, 2005 01:27 PM
MoogieBoogie
Apr 26, 2004 12:09 AM
