Anyone ever weld the combustion chamber of the H22???
Im just curious if anyone out there has welded the combustion chamber of the H22 to sort of resemble the GSR combustion chamber...
Heres a pic of a B16 head with the chambers welded up...
Im kinda curious, if theres someone out there who has done it did you by any chance cc the head to get the new combustion chamber volume?
Im trying to gauge what type of compression can be made with Type S pistons and a slightly smaller combustion chamber...
If the cc count can be brought to roughly 50cc's by doing this than compression could be somewhere in the 11.76'ish range...
that plus some flat top valves should get you right around 12.0 with all honda parts on the bottom end...
Just an idea... I hate milling the head
Modified by SoCalude98 at 7:35 PM 5/18/2004
