Anyones car follow grooves in the road?
My teg is only lowered about 1.25" w/o camber correction and when I was running stock size tires 195/60-14 it was fine. Every once in a while it'd follow a groove in the road and pull the steering wheel. I recently switched to 205/45-16's which are a bit over an inch wider, the car follows grooves much more now. It's mainly noticable on the freeway in certain areas of my commute. Has anyone else had this after they switched to wider tires?
i dont have a drop yet, but i have 17's on 205-40-17's and it pulls alot more, mainly cuz you have more traction because your riding on a wider surface area then be4.. took me a while to get used to it, but now im all good
still pulls side to side on un-even roads.. but im fine with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coke1980 »</TD></TR><TR><TD CLASS="quote">Michelin Potenza's eh?!
yup ....
</TD></TR></TABLE>yup ....
have you tried lowering your tire presure. my new rears were way high, like 46 psi and the car wandered like mad! I took them down too, 35 and most of it was gone. Really, the only sure fire way I know of is to do both fix and maintain you tire pressure and get a camber kit. of at the very least put a few washers in the rear set up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oblivion »</TD></TR><TR><TD CLASS="quote">have you tried lowering your tire presure. my new rears were way high, like 46 psi and the car wandered like mad! I took them down too, 35 and most of it was gone. Really, the only sure fire way I know of is to do both fix and maintain you tire pressure and get a camber kit. of at the very least put a few washers in the rear set up.</TD></TR></TABLE>
I'm running them at 38psi now. I don't want to get rid of the negative camber for handling reasons. I guess it's unavoidable with my setup. I do need to get my toe set (which is all they can align without a camber kit) because the steering wheel is off a little bit. I don't think my toe settings will change the bump steer but who knows.
simple physics my friend... tires are gonna follow where and how the road pitches. im lowered 2.25" up front and 1.75" rear on stock 95 fat fives 195/55/15's and it'll pull with the grooves
