rear suspension removal?
Old May 18, 2004 | 08:06 AM
blulude92's Avatar
Default rear suspension removal?
hey guys,
my helms manual says that in order to remove the rear struts, i need to separate the upper ball joints. i don't want to do that because i think it might be a pain in the *** and i also don't have the tool for it. is there any other easier way to do this (like removing the lower arm)? i wanna know before i start takin **** apart. how do u guys do it? thanx a lot.
-Steve
Old May 18, 2004 | 08:20 AM
AndyD's Avatar
Default Re: rear suspension removal? (blulude92)
I thought the rears were going to be HARD! It turned out that all I needed to do was hit the control arm three times with a regular hammer and it poped right out.
It was amazing how easy it was to remove the shocks. The biggest problem I had was having all the suspension pieces moved from my OEM shocks to the aftermarket. Almost two weeks later, I am still having issues with it. The ****** shop messed it up.
Old May 18, 2004 | 08:30 AM
Daemione's Avatar
I understand it's possible to remove the rear strut assembly by disconnecting the rear sway bar instead of the upper ball joint. But I haven't tried it - I've always just popped the ball joint. It's not hard, and the tool is cheap.
Old May 18, 2004 | 09:18 AM
blulude92's Avatar
Default Re: rear suspension removal? (Daemione)
where did u get the tool? i went to autozone and they didn't have it
Old May 18, 2004 | 09:19 AM
blulude92's Avatar
and also, to get the ball joint back in do u just tighten the nut till it pops in?
Old May 18, 2004 | 09:29 AM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blulude92 &raquo;</TD></TR><TR><TD CLASS="quote">and also, to get the ball joint back in do u just tighten the nut till it pops in?</TD></TR></TABLE>
You aren't actually popping out the ball joint. It is just the threaded piece on the ball joint. Basically, it is just the mounting point where the ball joint connects to the control arm.
I was owndering the same thing when I was pulling my suspension off. I was wondering how I would pop off the ball joint and then get it back in.
Trust me, it is not the way it sounds. The ball part of the joint is not affected. It is the threaded piece that attaches to the control arm that pops out.
I hope this makes sense.
Old May 19, 2004 | 07:29 PM
blulude92's Avatar
Default Re: rear suspension removal? (AndyD)
ok i did it. only had to remove the sway bar link and push the whole assembly down. a little bit of a bitch sliding it out but hey, just had to work at it.
Old May 19, 2004 | 08:51 PM
92LudeSI's Avatar
Wo wo wo you dont need to take anything off. If your talking about a 4th gen non 4ws nothing needs to come off. I have dont 2 ludes and took nothing off just have someone push on the wheel hub while you push the shock up to compress it and then pull it out. man that sounds like way too much work what you guys are doing.
dragonfly2k3
Jun 26, 2008 06:54 AM
pli
Honda S2000
17
Jan 30, 2008 07:37 AM
92civic_eg
May 7, 2004 02:50 PM
3 G's
Jun 1, 2003 01:15 AM
