Want to know a estimated 1/4 time on this setup...
Friend recently installed the following on a 2000 Gsr
FMAX StageII Kit w/t3/t4 turbo
ECU-Hondata s200,
skun2 stage II cams
A'PEX AVC-R DBC,
spoon valves
-n1-apexi exhaust
-ACT Clutch Street Strip
Extreme Pressure Plate
-Toda Flywheel
-Prothane Shifter bushing Kit
-B&E Shifter
-Vitek Plug Wires
-AEM Front + Rear Brakes
-Apex Rev/Spd Meter
312whp/201 trq @ 7-8 psi
Do the numbers look good, or should they be higher or lower, and what approximate time should he run at the 1/4 with 8 pds of boost.
ECU-Hondata s200,
skun2 stage II cams
A'PEX AVC-R DBC,
spoon valves
-n1-apexi exhaust
-Toda Flywheel
-B&E Shifter
-Vitek Plug Wires
-Apex Rev/Spd Meter
with that set-up and that whp you should be in the 12's somewhere. there are too many variables though. track conditions, slick size, weather, driver, and so on...and so on...you won't get close to 10's unless your buddy's gs-r is a tube framed race car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDA9x »</TD></TR><TR><TD CLASS="quote">Why not take it to the track and find out? There are many factors besides the mods done to the car to distinguish 1/4 times..</TD></TR></TABLE>
excato... how in the hell do we know?
ive seen people make carzy power and run shitty numbers, and ive seen people not makiong so much power and running good, your driving and suspention, along with other fators will determine your times at the track
NewbyforIntegs
Mar 26, 2004 07:08 PM
SOUNDEFFECTS
Dec 7, 2001 10:24 PM
