Has anyone else managed to do this yet?
I think this happened Sunday autocrossing. I noticed it yesterday. Only the bar seems to be messed up, the subframe and the alignment are still where they've always been, so I guess the bar saved it, but damn. I thought the reinforcement bar would have been stronger than that. If it was all bling, the least they could have done was engrave or paint "SPOON" on the bar. At least then I would have felt like I got something out of it.
Oh well, I guess I gotta make my own now....
Yeah, the subframe is still fine, there's nothing wrong with the sway bar. I looked at it again, its a smooth bend, no kink... so I don't think it buckled. I took a turn out of the threaded end, I'm gonna see if it relieves the stress and straightens out.
looks like independent suspension works well. the sub-frame could have never done that. i'd say control arms. now you need a better sway bar- tie bar combo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh0rti »</TD></TR><TR><TD CLASS="quote">could someone explain to me where the sway bar/tie bar is located... i see the bent bar.. which bar is that called? lol</TD></TR></TABLE>
tie rod/ bar
tie rod/ bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc5 »</TD></TR><TR><TD CLASS="quote">I don't understand how that Spoon bar can be bent like that, while everything else remains fine. I just don't understand how that would happen. So much for everyone saying the rear subframe of the DC5 is strong enough and that it doesn't need the Progress rear tie bar....</TD></TR></TABLE>
Well, they made it out of aluminum, thats problem #1. Everytime it flexes it gets weaker and tiny cracks begin to develop.
Problem #2 is that its hollow, so its got relatively thin walls and room to move.
So basically what I think happened is all the beating it's gotten, its just been cycled so many times, it basically just gave out. It probably could have done this without causing damage to the rest of the car because the subframe and the other parts down there all appear to be steel, which is far stronger to aluminum when it comes fatigue, and if its doing its job re-inforcing that subframe, then it appears to have done its job.
For now, I'm planning on just replacing the Spoon crossbar with a solid chrome-moly (4140 alloy) rod. Ultimately, I'll end up with something better, I just need a quick fix at the moment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc5 »</TD></TR><TR><TD CLASS="quote">So much for everyone saying the rear subframe of the DC5 is strong enough and that it doesn't need the Progress rear tie bar....</TD></TR></TABLE>
I think this is a 02 EX civic, do they have the same chassis as the DC5?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch2k »</TD></TR><TR><TD CLASS="quote">Nope, the EP3Si doesn't come with the integrated tie bar...I dont know if the CTR does or not.</TD></TR></TABLE>
CTRs come with front and rear antiroll bars
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03ephatch »</TD></TR><TR><TD CLASS="quote">CTRs come with front and rear antiroll bars</TD></TR></TABLE>
All the EP3's have them, but I mean the little tie bar in addition to the rear anti-roll bar.
