Water Leak from my teg
Old May 18, 2004 | 03:46 AM
Uneekpinoysk8er's Avatar
Default Water Leak from my teg
well i notice that theres a really bad water leak on my car. from what i could tell it appears to be dripping from a hose thats pointed towards the floor. i really ahve no idea what it could be, can anyone offer any possible reasons as to why this is happening?
Old May 18, 2004 | 04:22 AM
JimBlake's Avatar
Default Re: Water Leak from my teg (Uneekpinoysk8er)
What fluid is dripping? Anti-freeze has a destinctive smell. Oil, transmission fluid, PS fluid, brake fluid... all those are oily.
If it just plain water, then it could be condensation from running your AC. That's normal.
Old May 18, 2004 | 06:30 AM
Default Re: Water Leak from my teg (JimBlake)
yea it seems like plain water and it does happen when i run my AC, but theres a lot of water and i wasnt sure if that was normal or not.
Old May 18, 2004 | 07:14 AM
4dr_GS-R's Avatar
please be more specific...
Old May 18, 2004 | 08:41 AM
TrueUntilDeath.com's Avatar
Default Re: (4dr_GS-R)
cracked windshield wiper resviour?
Old May 18, 2004 | 10:21 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (NA Integra)
does it run IN the car or under the car? I have water leaking under my car from the hose leading from the charcoal canister now and then. That's normal. If it's leaking inside the car on the passenger side floor, you might try looking under there and reconnecting the hose...they come loose quite often.
Old May 18, 2004 | 06:28 PM
vietguy's Avatar
try searcing.
here ya go:
https://honda-tech.com/zerothread?id=866524
Old May 18, 2004 | 06:51 PM
Toddgsr's Avatar
It might be through the taillights...mine did that but i just put a sealer around it
Old May 18, 2004 | 07:10 PM
satoshi's Avatar
Default Re: Water Leak from my teg (Toddgsr)
if theres water leaking from under the car.. its normal.. happens every once in a while.. but if its leaking inside the car.. check http://www.g2ic.com/tegtips/ .. under interior..
Old May 18, 2004 | 07:59 PM
brotechacura's Avatar
Is the car running hot or is water low?
Old May 18, 2004 | 08:07 PM
m R g S r's Avatar
Default Re: Water Leak from my teg (brotechacura)
It's probally the AC drain.
No-Gi
Oct 3, 2009 06:30 AM
EvenStar
Jul 30, 2008 11:19 AM
syler
Apr 23, 2007 04:42 PM
Josh Carr
May 12, 2004 08:10 AM
Understeer
Jul 23, 2003 02:53 PM
