got new pads/rotors, need brake fluid?
Old May 17, 2004 | 11:39 PM
typeass's Avatar
Default got new pads/rotors, need brake fluid?
I just got new pads/rotors. Do I need to change the brake fluid as well during the install or could I just keep the same oem stuff? Thank you.
Old May 18, 2004 | 01:19 AM
Slow_Em1's Avatar
Default Re: got new pads/rotors, need brake fluid? (typeass)
yes make sure to get DOT4 or up, nothing less
Old May 18, 2004 | 05:20 AM
wilsel's Avatar
Default Re: got new pads/rotors, need brake fluid? (Slow_Em1)
You don't have to change the fluid. If it has more than 50K miles on it, it would be a good idea though.
Old May 18, 2004 | 07:22 AM
Vince Kay's Avatar
Default Re: got new pads/rotors, need brake fluid? (wilsel)
I changed mine recently... no need to change fluid, just make sure that you pump the brake pedal after you release the calliper clips to ensure that the fluid gets all the way into the system.
If anything, you will have a higher level of fluid in your resevoir due to the thicker NEW pads replacing your old worn THIN pads
But as Slow said... replace over 50k miles...
Old May 18, 2004 | 07:54 AM
jonas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 &raquo;</TD></TR><TR><TD CLASS="quote">yes make sure to get DOT4 or up, nothing less </TD></TR></TABLE>
incorrect. dont use DOT 5
Old May 18, 2004 | 08:11 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: got new pads/rotors, need brake fluid? (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas &raquo;</TD></TR><TR><TD CLASS="quote">
incorrect. dont use DOT 5</TD></TR></TABLE>
Exactly.
DOT 5 sucks ***** for cars because it requires much more bleeding and more frequent bleeding.
Also you don't even have to disconnect the brake hosrs on the calipers to do front pads and rotors - no need to buy fluid.
Old May 18, 2004 | 08:44 AM
jonas's Avatar
DOT 5 is also silicone base opposed to the norm. glycol base
Old May 18, 2004 | 09:51 AM
typeass's Avatar
Default Re: (jonas)
Thanks guys for the responses!
Old May 18, 2004 | 10:15 AM
typeass's Avatar
Default Re: (typeass)
Slow_em1 has a website in his sig about another site, I guess they don't know much there.
GoLowDrew
Oct 6, 2015 06:03 AM
Newbie808
Mar 29, 2012 08:17 AM
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
itr1244
May 17, 2004 01:31 PM
Dan GSR
Oct 1, 2002 12:22 AM
