Which spark plug wire set would be the best?
Old May 17, 2004 | 08:53 PM
Sprockett's Avatar
Default Which spark plug wire set would be the best?
Between NGK, Nology, Magnecore, and the stock wires...which would be the best to have? I know it's not going to make THAT much of a difference, but I don't want to have inferior stuff with my turbo GSR (in the works). If there's not that much of a difference between stock and the others, I won't bother...but if there is, I may just have to pick up a set.
Old May 17, 2004 | 08:54 PM
threatcon13's Avatar
New User
Default Re: Which spark plug wire set would be the best? (Sprockett)
stock
Old May 17, 2004 | 08:57 PM
frenchy's Avatar
youre gonna get someone who will recommend all of them - i have nology and i can attest as will many others that theyre not worth the money - most would recommend magnecor or ngk blues for now and if(when you go turbo)
Old May 17, 2004 | 09:01 PM
TrueUntilDeath.com's Avatar
Default Re: Which spark plug wire set would be the best? (Threatcon13)
a lot of people running boost run ngk v-powers. they last for a few months of beating. i use them for my stock motor. just like oem
Old May 18, 2004 | 01:43 AM
Slow_Em1's Avatar
OEM...nothign else unless you are going FI
Old May 18, 2004 | 03:54 AM
scrap1ngsr's Avatar
Default Re: Which spark plug wire set would be the best? (Slow_Em1)
I spent about 65 bucks on some NKG performace spark plug wire set and it felt the same as my oem stock ones but my gas mileage dropped. I say stick with oem
Old May 18, 2004 | 04:42 AM
furious94ls's Avatar
Default Re: Which spark plug wire set would be the best? (CivicSiR94)
Stock, NGK blue, MSD all good quality wires. So find your best price.
Old May 18, 2004 | 07:08 AM
greaseball's Avatar
i've been running the same set of magnecore 10.5mm for over 2-1/2 years. they last for a long time. i have friends who use them on high hosepower turbo applications and they have lasted just as long. i would recommend these to anyone. of course, you want to go with the 8.5mm.
Old May 18, 2004 | 07:09 AM
greaseball's Avatar
Default Re: Which spark plug wire set would be the best? (greaseball)
use the 8.5mm until you go turbo. and i meant high horsepower not hose power. haha
Old May 18, 2004 | 09:04 AM
Devlins 91LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockett &raquo;</TD></TR><TR><TD CLASS="quote">I don't want to have inferior stuff with my turbo GSR(in the works)</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 &raquo;</TD></TR><TR><TD CLASS="quote">OEM...nothign else unless you are going FI</TD></TR></TABLE>
:rolls eyes: useless bastard
Old May 18, 2004 | 10:21 AM
Deluzional's Avatar
Im still using Oem with my setup, and I dont plan to buy anything else
Old May 18, 2004 | 10:36 AM
Teknic73's Avatar
Default Re: Which spark plug wire set would be the best? (Deluzional)
&lt;-- uses Denso Iridium
Old May 18, 2004 | 11:18 AM
4U2NV's Avatar
&lt;----- Strictly stock when I was boosted and N/A...
Svell
Mar 31, 2011 12:57 PM
alloysr16s
Jun 9, 2005 09:36 PM
Keith P
Apr 8, 2005 10:05 AM
sidoe
Mar 13, 2002 09:23 AM
Ignitecivic
Jan 12, 2002 05:26 PM
