Fiberglass Door Panels for a CRX???
Old May 17, 2004 | 08:47 PM
rhetorical's Avatar
Default Fiberglass Door Panels for a CRX???
I took off my door panel and ditched the seat belt, butnow i'm left with this bulky door panel, that i dont really need to be massive, however, its unsightly if i just yank it off and leave it off. Has anyone seen any fiberglass door panels for an '89 CRX? I'm just modding my current ones but its extremely tedious and not comin out too good, so i'm thinkin of either makin one or just finding some. Anyone know anything?
Old May 17, 2004 | 09:49 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Fiberglass Door Panels for a CRX??? (rhetorical)
Seeing as though you took off your door panels already. You might of noticed they don't weigh a damn thing to begin with. I weighed mine and they weighed 3.5 pounds each. I don't really think its worth it, but I"m no help because I don't any companies who make such a peice. But its going to be damn expensive probably, hopefully not.
Old May 18, 2004 | 12:03 AM
vitrox's Avatar
http://www.teamprototype.com has some fg door panels, but they look NOTHING like the originals.
Old May 18, 2004 | 09:11 AM
rhetorical's Avatar
Well i've got no use for those holes where the seat belts went. And Vitrox-those things are expensive as shizel, anyone have any ideas on on building one myself?
Old May 18, 2004 | 09:15 AM
crx_88_si's Avatar
how about gettin some 88 HF ones?
Old May 18, 2004 | 11:53 AM
rhetorical's Avatar
Do they not have door-mounted seatbelts? Do you have any pictures? Perhaps you're selling some?
Old May 18, 2004 | 01:12 PM
0-60pdog's Avatar
Default Re: (rhetorical)
88 CRX seat belts went to the floor not the door. I'm not sure if they bolt up to 89 CRX because of the seat belt mounts. But I'm sure they can be fit with a little Fabrication work!!!! Maybe you could look at a local junk yard for the entire door and panels off an 88 CRX, since door belts are not needed in your ride.
Old May 18, 2004 | 01:25 PM
crx_88_si's Avatar
89 HF's also had car mounted seat belts, not door mounted.
Old May 18, 2004 | 05:29 PM
rhetorical's Avatar
unfortunately i'm located in a junkyard deprived location. Anyone got some of these?
also, how hard would it be to switch the whole door? Wiring and everything?
Old May 18, 2004 | 05:35 PM
ExplicitSpeed's Avatar
88-89 honda crx's had seatbents not on the door and the door panels will not fit on a 90-91 crx because there is a reason there is a bulge in the door panel in the 90-91's the seat belts went there and I think the metal will not form to the 88-89 door panels the bolts that held up the seat belts in the 90-91 stick out a ways and hit into the 88-89 door panels and I believe the 90-91 doors are little bit larger or smaller forgot then the 88-89, I think the glass is smaller on the 90-91 crx. I have also messed around with fiberglass on the door panels and it doesnt work good on the vinyl or atleast have a pro do it. Make sure you have an extra set if your goin to try to fiberglass
Old May 18, 2004 | 05:47 PM
rhetorical's Avatar
Screw the pro doin it . I'm cheap. And i've allready torn off all of the vinyl, and i'm getting rid of all of the adhesive, i allready cut out where the seat belt was on the lower part. I'm still deciding between just completely taking out that bulge or just rounding it off. It would leave me with more interior room if i took it out but i dunno about my skill level. I'll keep yall updated on my crappy craftmanship =D
Old May 18, 2004 | 09:37 PM
0-60pdog's Avatar
Default Re: Fiberglass Door Panels for a CRX??? (89crxhfLST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxhfLST &raquo;</TD></TR><TR><TD CLASS="quote">88-89 honda crx's had seatbents not on the door</TD></TR></TABLE>
I have an 89 CRX si and it has seat belts in the door. I dont know about any other CRX models, though!
Any way, I think rhetorical should keep on trying. The mold is the hardest part!!!
Old May 19, 2004 | 01:54 PM
rhetorical's Avatar
Default Re: Fiberglass Door Panels for a CRX??? (0-60pdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0-60pdog &raquo;</TD></TR><TR><TD CLASS="quote">Any way, I think rhetorical should keep on trying. The mold is the hardest part!!!
thanks man
Old May 19, 2004 | 02:36 PM
0-60pdog's Avatar
when it is finished show some pics. I might want to buy a set!!!!!
Old May 20, 2004 | 12:19 PM
rhetorical's Avatar
Any suggestions on making the mold? Right now i've just cut out the bulges and what not, i'm going to fiberglass over those quite large gaps. However, I'm not sure if I need to make a mold if I'm not producing multiple ones.
Old May 20, 2004 | 02:52 PM
xci_ed6's Avatar
You could just use a flat panel of aluminum, fiberglass, or carbon. Doesn't look stock but easy and light.
Old May 20, 2004 | 03:31 PM
CRX_GUY_123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">Seeing as though you took off your door panels already. You might of noticed they don't weigh a damn thing to begin with. I weighed mine and they weighed 3.5 pounds each. I don't really think its worth it, but I"m no help because I don't any companies who make such a peice. But its going to be damn expensive probably, hopefully not.</TD></TR></TABLE>
exactly....
Old May 20, 2004 | 08:43 PM
rhetorical's Avatar
yah but once again... i didn't do it for weight, if i did it for weight why would i want to put them back on...? c'mon guys i said i did it to remove the seat belts, those weigh more than 3.5lbs trust me. and now i have an unsightly bulge wwhere they used to be, and holes on teh top and bottom where the seat belt used to run through...
anyone have some HF ones or some that didn't have the door mounted seat belt they wanna sell?
Old May 28, 2004 | 01:26 PM
Turbo'dMex-A-Keen's Avatar
MMRUSA.com has them, like 550 a set or something
Old May 28, 2004 | 06:12 PM
rhetorical's Avatar
Pancho i believe what you're talking about are the doors, i just need the door panels
Old May 28, 2004 | 10:09 PM
ohh i see, man make some outta tin haha
singlecamsaint
16
Mar 5, 2012 04:44 AM
joeyblow
Oct 2, 2005 02:41 PM
ZCpoweredCRX
Apr 4, 2004 10:20 PM
.ShawnD.
11
Nov 12, 2002 05:45 AM
