When Separating Front Hub from Spindle, Do I need to Replace Wheel Bearing?
Old Nov 7, 2001 | 06:21 AM
pcorad's Avatar
Default When Separating Front Hub from Spindle, Do I need to Replace Wheel Bearing?
I need to replace a couple of damaged wheel studs. To do this I need to separate the hub from the spindle (any advice on this?).
Will I trash the front wheel bearing in this process? With 86K miles on the ITR, should I just replace the wheel bearings regardless?'
Paul
Old Nov 7, 2001 | 11:04 AM
KekeK-18's Avatar
Default Re: When Separating Front Hub from Spindle, Do I need to Replace Wheel Bearing? (pcorad)
I reused mine last time...but aways a good idea to replace it. (The bearing needs to be pressed out anyway.)
Old Nov 7, 2001 | 04:55 PM
fixhondas's Avatar
You don't have to replace the bearing- you should be fine as long as you don't get a bunch of dirt on the bearing or race.
ketchup
17
Jun 27, 2008 09:02 PM
Devo94ac
Jan 16, 2006 06:08 PM
nwdrifter
Sep 28, 2004 12:15 PM
pcorad
Nov 7, 2001 08:41 AM
