When Separating Front Hub from Spindle, Do I need to Replace Wheel Bearing?
Old Nov 7, 2001 | 06:20 AM
pcorad's Avatar
Default When Separating Front Hub from Spindle, Do I need to Replace Wheel Bearing?
I need to replace a couple of damaged wheel studs. To do this I need to separate the hub from the spindle (any advice on this?).
Will I trash the front wheel bearing in this process? With 86K miles on the ITR, should I just replace the wheel bearings regardless?'
Paul
Old Nov 7, 2001 | 06:38 AM
tjtruong's Avatar
New User
Default Re: When Separating Front Hub from Spindle, Do I need to Replace Wheel Bearing? (pcorad)
its not a necessity, but you should just because the bearing could be roughed up a bit when seperating the hub from spindle. If you carefully took it out i don't see why you would need to replace it. but if it were me i would just replace it because Its one of those things that would make me sleep better. Hope this helps..
tj
Old Nov 7, 2001 | 08:41 AM
lucas569's Avatar
Default Re: When Separating Front Hub from Spindle, Do I need to Replace Wheel Bearing? (tjtruong)
yes the bearing is a sealed unit,never needs greasing. i did this once,repacke it with grease and put it all back together andlow and behold it started making noise and shaking a little. the dealer had to press a new one in for me. i just brought them the whole arm $45 part $60 labor.
RacerTim
Sep 10, 2010 05:44 PM
ketchup
17
Jun 27, 2008 09:02 PM
yung98gsr
Feb 18, 2005 09:28 AM
