Question for all b-series swap
Old May 17, 2004 | 07:48 PM
CrazyKoreanCrx's Avatar
Default Question for all b-series swap
Where did you hook up your map sensor to the firewall or off the t.b. . My buddy and me are both doing swaps in our crx's and would like to know where to put the map sensor to. I have a b16a2 and the other is a b16a. So thanks for the help.
Old May 17, 2004 | 08:07 PM
Rywire's Avatar
Default Re: Question for all b-series swap (CrazyKoreanCrx)
Take your pick, if the map is on the tb on your swap, extend the wires, and hook it up. If not, leave it how it is. Ryan
Old May 17, 2004 | 08:24 PM
Default Re: Question for all b-series swap (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Take your pick, if the map is on the tb on your swap, extend the wires, and hook it up. If not, leave it how it is. Ryan</TD></TR></TABLE>
Thanks Ryan, You mine hero.
Also another question how did you do your vaccum lines on the gsr motor?
Old May 17, 2004 | 08:27 PM
Craps I for got another question what Gauge of wire to use for the wiring?
Old May 17, 2004 | 08:29 PM
Rywire's Avatar
ill tell you for sure in a week. The b16 will be out this weekend. Are you doing a gsr swap?
As far as the vac lines... It should be pretty easy. Its basically the same as the 16.
http://www.geocities.com/droppedcrxsi/vacuum1.htm
Old May 17, 2004 | 08:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">ill tell you for sure in a week. The b16 will be out this weekend. Are you doing a gsr swap?
http://www.geocities.com/droppedcrxsi/vacuum1.htm</TD></TR></TABLE>
Thanks, yea i'm dropping a gsr with a si bottom end and j1 tranny. Right now i'm just buy misc. parts and after I came back from las vegas. I'll be putting the motor together and suspension and wiring around june. I need to be really before a bbq meet and a hin.
brians efhatch
Feb 14, 2011 08:00 AM
Brian Hinson
13
Jun 24, 2006 04:05 PM
j-robsDA
May 31, 2005 08:08 AM
dropd4door
Dec 27, 2004 05:13 PM
ELSpool
Jan 14, 2004 05:47 PM
