washed my engine bay, now i have electrical problems
Old May 17, 2004 | 06:52 PM
thecorey's Avatar
Default washed my engine bay, now i have electrical problems
today i sprayed my engine bay with simple green and then sprayed it out with a hose, i let it sit for about an hour....i got in the car..and when i opened the door some lights on the gauge cluster were really dim..but the key wasnt even in the ignition....the lights came on when i opened the door....then i started it up.the electrical components wouldnt really work....it seemed like the battery was dead....but it had plenty of juice to start the engine....eventually they started working a little...and thats how it is now...when i try to turn the headlights on..the interior lights dim or go off...and everything is flickering.....if i let it sit for a day or so..will it just go away?? what the hell is going on?
Old May 17, 2004 | 07:18 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: washed my engine bay, now i have electrical problems (thecorey)
Next time be careful what you spray water on, and spray your engine while its RUNNING
Old May 17, 2004 | 07:42 PM
crxgator's Avatar
Default Re: washed my engine bay, now i have electrical problems (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Next time be careful what you spray water on, and spray your engine while its RUNNING </TD></TR></TABLE>
i leave mine off, i just take out the battery, cover the distributor and intake and off i go...worked fine for me...
you probalby have to let it dry out some more...
Old May 17, 2004 | 07:52 PM
EL Vap133's Avatar
Yeah, let it dry off and it might help.
Old May 17, 2004 | 08:39 PM
fourthgenhatchB17's Avatar
If u wanna do this with the engine running, you have to be careful. Depending on how long it is running, the exhaust manifold could get hot very quickly and spraying water on it could crack it.
Now what u wanna do is get the engine warm, not hot, turn off engine, and spray your cleaner where ever desired. Let sit for a bit and then follow up with low pressure water. Like someone else stated, cover the distributor and dont really spray water where its not needed.
Old May 17, 2004 | 09:57 PM
Donkey85's Avatar
Default Re: washed my engine bay, now i have electrical problems (fourthgenhatchB17)
i usually do it while its off too, but while the engine its still warm works like a champ
Old May 18, 2004 | 12:02 AM
vitrox's Avatar
i pulled my engine, then did it.
Reagan Howell
Honda Civic (2001 - 2005)
Nov 29, 2018 06:45 PM
LoSt187
Honda CR-V & Element
Dec 22, 2017 03:08 PM
odysseypunk31
Aug 23, 2016 02:01 PM
em.kuske
Oct 23, 2012 09:26 AM
Mr. Giggles
31
Aug 27, 2006 12:01 PM
