clutch replacement
just take the tranny out
axles come out
un hook shift linkage
take starter out
trannys mounts ground wire all the wire that plug into the tranny and slide out make sure u put a jack under the motor
axles come out
take starter out
car up, wheels off, drain tranny, axles out of hubs, axles out of tranny, intake tube off, starter off, header off, tranny off, pressure plate off, clutch off - reverse process for on.
I think I covered it all.. but a haynes would help a little, a helms would help a lot.
boostincoupe
Apr 2, 2006 05:22 PM
? I did a search and couldn't find any detailed info...
