Going to buy a crx.... what motor should i drop in it?
Old May 17, 2004 | 06:08 PM
petergun's Avatar
Default Going to buy a crx.... what motor should i drop in it?
Thinking of a B18C if I can afford it..(probably not)
Budget will probably be $2000 including install
what do you guys think?
Old May 17, 2004 | 06:22 PM
blackmagicCRX's Avatar
Default Re: Going to buy a crx.... what motor should i drop in it? (petergun)
for your budget a B16A would prolly be the best. If you know how to use normal tools it is actually a straight forward swap. if you aren't that good with wiring find a friend that knows how to soldier and there are plenty of diagrams all over the net on how to wire it up. good luck
Old May 17, 2004 | 06:45 PM
petergun's Avatar
Default Re: Going to buy a crx.... what motor should i drop in it? (blackmagicCRX)
Hey, thanks for the insight. What do you think about a b18 or a b16b?
Advantages/Disadvantages?
Old May 17, 2004 | 07:11 PM
-16V-'s Avatar
B18 Good platform
N/A LS, Turbo LS, LS V-tec...
B16b Over priced
Pretty much a factory modded b16a
Ever thought about the D series single cam motors????
D16z6, D16y8,D16a6....
Pretty good for some boosting...
Just do alot of research before u buy a motor...Because i went out and bought a b16a full swap and its still sitting in my garage....
Yea yea i know...I dont know it's just something about the single cam turbo that gives me chill's....Gotta love bring the underdog to the top...
Old May 17, 2004 | 07:35 PM
Rywire's Avatar
Default Re: Going to buy a crx.... what motor should i drop in it? (-16V-)
You wont get much for 2k, thats for sure. Prolly just a sohc vtec. Ryan
Old May 17, 2004 | 10:30 PM
ceLtic's Avatar
N/A wh0re!
i say a small block
Old May 18, 2004 | 09:17 AM
petergun's Avatar
Just gonna buy a CRX with a b16a swapped in it
Thanks everyone
What mods next?
Old May 18, 2004 | 11:42 AM
wtsexton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -16V- &raquo;</TD></TR><TR><TD CLASS="quote">
B16b Over priced
B16B is pretty much a destroked ITR. Using longer rods and a b16a crank but the block is the same as the b18c.
Old May 18, 2004 | 11:47 AM
HumanResource's Avatar
What's wrong with the stock engine?
Old May 18, 2004 | 12:58 PM
Rywire's Avatar
Default Re: Going to buy a crx.... what motor should i drop in it? (wtsexton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton &raquo;</TD></TR><TR><TD CLASS="quote">
B16B is pretty much a destroked ITR. Using longer rods and a b16a crank but the block is the same as the b18c.</TD></TR></TABLE>
This is true. Ryan
Old May 18, 2004 | 01:01 PM
michael O's Avatar
Default Re: (petergun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petergun &raquo;</TD></TR><TR><TD CLASS="quote">Just gonna buy a CRX with a b16a swapped in it
Thanks everyone
What mods next?</TD></TR></TABLE>
I/h/e to start probably.
Old May 18, 2004 | 01:07 PM
spaceman's Avatar
hemi
Old May 18, 2004 | 07:25 PM
CRXRageD's Avatar
I say buy the car first, ask questions later.
Old May 18, 2004 | 08:59 PM
vitrox's Avatar
$2000 isn't a lot to work with.. my complete b16a swap i just ordered was just shy of $2400
Old May 18, 2004 | 09:28 PM
Almai's Avatar
Just an idea.
ls block 1-300 legit
b16 head 3-400 complete
a1 trans 150-250
pr3 ecu 150
dist. 1-150
mounts 200
linkage and axles 200
rear t bracket 50
hf si harness 1-150
throttle cable from 90 teg 15
exhaust?
All for about 2k
Old May 18, 2004 | 10:47 PM
MatHadder's Avatar
Get a wankel rotary. they are the best.
NsX_CrX
20
Aug 21, 2005 06:47 PM
stickyfingers
Feb 24, 2004 06:21 AM
LazYRaCeR
10
Jan 2, 2003 06:39 PM
ridnmyhonda
May 16, 2002 04:59 PM
MXPX
Jul 26, 2001 03:55 PM
