how to change clutch
Old May 17, 2004 | 05:14 PM
skeetman's Avatar
Default how to change clutch
well i have a 96 integra
well i need to know if i should go aftermarket clutch or stock im going all looks and not crazy hp
my car has no slipedge but when i press the clutch it stay ingaged i figured its probly the release bearing or just the springs on the clutch
another q do i need to remove the k member inorder to take out the trans? ow yea where can i go to get a good price on a clutch?
thanx for the help,
Old May 18, 2004 | 04:46 AM
JimBlake's Avatar
Default Re: how to change clutch (skeetman)
If it doesn't disengage when you press the pedal, it could be as simple as air in the hydraulic system. Bleed your clutch.
Old May 18, 2004 | 10:12 AM
skeetman's Avatar
Default Re: how to change clutch (JimBlake)
well i started taking **** apart and when i went to drain the trany there was no trans fluid could that cause my problem?
Old May 18, 2004 | 11:54 AM
JimBlake's Avatar
uuhhhh... sure that can cause all kinds of problems.
GranddaddyPurple
Feb 10, 2008 04:33 AM
B18Redline
Nov 13, 2007 11:09 AM
akteamster
Sep 12, 2004 08:06 PM
Buckshot
Nov 17, 2002 08:43 PM
Buckshot
Sep 11, 2002 05:05 AM
